Hiby R6 Pro - serious upgrade to popular DAP
Jul 24, 2019 at 8:45 AM Post #2,236 of 4,002
Thanks for the response. I will have to check the card on one of my other players. I am not sure if it is a Hiby thing or my files are not tagged correctly. Do you know of a good tagging program? I have used MusicBrainz Picard, but it constantly crashes.
mp3tag?
Jul 25, 2019 at 12:18 AM Post #2,238 of 4,002
I got the R6 for few days now, but wondering if it is normal when playing some music the unit is kind of very warm even screen off and not even connected to the power ?
Jul 25, 2019 at 12:43 AM Post #2,239 of 4,002
Jul 25, 2019 at 1:38 AM Post #2,240 of 4,002
Depends. If you're playing from the regular headphone out (not balanced) and this happens, could be the permissions bug, to be fixed thus:
https://www.facebook.com/hibycom/posts/1487231671419050
Hey joe, so... i have this problem where if i unplug my headphones from the SE output the unit still detects as if the headphones were still on, thing wouldn’t be annoying if I only used headphones but I actually use the coax out quite a bit at home and unless the se goes off, it doesn’t change the output to coax or LO... got any help for that one? I think is a physical problem with the physical output itself, i bought my unit back in April or May, piroblem didn’t appear until recently, like 3 weeks from now
Jul 25, 2019 at 4:13 AM Post #2,241 of 4,002
Well actually I am using a balanced cable for my headphone is it the cause of the problem and anyway i gave all permissions according to your link
I got an other concern the android security patch level is dated from December 2017 I do not expect to get the latest one from this month like on my phone, but 2 and half year old kind of worry me a bit, and definitely wont put any sensitive data on it ,since some of the major vulnerability have not been patched!.
Jul 25, 2019 at 4:09 PM Post #2,242 of 4,002
Yes it does seem like a hardware problem :frowning2:
I'll talk to the devs about possibility of updating this but in the meantime I hope it's not necessary to put anything more than your TIDAL, Spotify etc. passwords on your music player :sweat_smile:
Jul 25, 2019 at 7:50 PM Post #2,245 of 4,002
Is there anyway to grant access to windows to see the internal storage and sd card? With my Fiio's it was plug and play now I have an r6 pro icon with an empty folder. I have tried everything before asking. Thanks.
You have to enable file transfer in the settings.
Jul 26, 2019 at 12:20 AM Post #2,247 of 4,002
Under the notification bar, when you plug in a USB cable, you'll see Android System. Tap it twice and you get three options. Charge This Device, Transfer files and USB DAC in.
You will also need to install "Android File Transfer" if your computer is a Mac.
Jul 26, 2019 at 6:36 AM Post #2,248 of 4,002
Has anyone compared the sound quality of the R6Pro to Fiio's M11?
Jul 26, 2019 at 8:17 AM Post #2,249 of 4,002
Thanks, feel pretty stupid... but just getting used to this device... I have another ? Is there anyway to prevent bluetooth from automatically turning itself on? Thanks!
Is there any way to turn the storage into drives like Fiio Does? That's what I meant... I figured out how to add music when I first got it.
