If you are in the main screen, simply press and hold the Power button. From there you can choose to either Power Off or Restart.To reboot Pro II you need to press Power + Skip Prev. Which button is Skip Prev? I'm always getting mixed up with buttons as this is the only Dap I have the plugs in from the bottom. tx
Hiby R6 Pro II (2023 Edition) - Launch, Hype, Thoughts & More
- Thread starter Zaghamkarim
Furiousipaduser
Really impressed with the R6 Pro II, been using my kiwiears Quintet and ie600s and loving it.
Stu Paddasso
I guess I could have stated this better. I'll try again. In case I'm having trouble with Pro II and need an emergency reboot which 2 buttons do I push and where exactly are those 2 buttons located?
Oh I see.I guess I could have stated this better. I'll try again. In case I'm having trouble with Pro II and need an emergency reboot which 2 buttons do I push and where exactly are those 2 buttons located?
I think Hard Reset is Hold Power button for 30+ seconds until the device reboots but I'm not sure.
Wow, and what an explanation that is. Must admit I actually understood very little of it. As long as it drives my Z1Rs to their full potential I don’t care what the output is. Now if only HiBY could do something about that loud hiss that is in my head.. sigh..Pure black background even with sensitive IEMs (No hiss).
This is explained clearly on the official product page of Hiby.
Once you receive it, would you mind reporting here your impressions of it? I’m curious. And as you said, if it makes the side buttons anymore tactile.Ordered from official Dignis store on ebay.
https://www.ebay.de/itm/374868423802
Of course. I'm not sure how long it takes, but I will update here when I get it.Once you receive it, would you mind reporting here your impressions of it? I’m curious. And as you said, if it makes the side buttons anymore tactile.
jsmiller58
Am I reading the price correctly? Nearly $100 for a case?Of course. I'm not sure how long it takes, but I will update here when I get it.
If 4.4 on class A amp has a power output of 383mW, what output does 4.4 have on the class A/B amp? Anyone know?
Zaghamkarim
These are Dignis cases, they are "premium" case designers - the equivalent of "Mous" Cases or "Casetify" cases for iPhone, you can get cheaper cases.Am I reading the price correctly? Nearly $100 for a case?
Yes, supports MP4 & if I'm not mistaken a new update allows playback of FLAC inside MP4 containers.can this play mp4 files?
As far as I'm aware - the power output only changes between the single-ended (3.5mm) and balanced (4.4mm) ports. The power output is not changed by switching between the amplification types, that only changes the efficiency (hence battery life) and some may notice a slight difference in sound signature.If 4.4 on class A amp has a power output of 383mW, what output does 4.4 have on the class A/B amp? Anyone know?
jsmiller58
There apparently is a lot of money out there...These are Dignis cases, they are "premium" case designers - the equivalent of "Mous" Cases or "Casetify" cases for iPhone, you can get cheaper cases.
Yup ! Apparently it's real Italian Leather.Am I reading the price correctly? Nearly $100 for a case?
All Dignis DAP cases are priced like that.
You could buy refurbished cases for half the price on some websites.
Weren't you all praises about the $5k N30LE which doesn't offer too much more than the Hiby R6P2 and costs 8 times more (EU) ? Now you're complaining about a genuine leather $100 beautiful DAP case ?
LMAO !
You should write this comment in the N30LE thread where it belongs !
The N30LE + UM IEM bundle in EU costs 14500 EUR !! Those guys at Cayin are insane !
ma151
Hi,
Do any of you guys tried using R6 Pro II with HQPlayer on USB DAC mode ?
If so, why it's limited to 768k PCM/DSD256 ? Will there be a firmware update to fix this ? Or maybe is a limitation on my end as I'm using the trial version ? (I began using today after Passion for Sound video and it really sound outstading and straigh up better than Audirvana )
