auronthas
- May 19, 2017
Hi Joe, any progress and solution pertaining to my previous query/issue. Please assist. TqLet me ask the tech staff for further opinion...
Same here. Using the newly released KZ ZS10 Pro with mic right now and it sounds great. Mic control does nothing though. BTW if anyone wants a great sounding budget iem KZ has knocked it out if the park with the ZS10 Pro. Just incredible sound. So similar to the Moondrop Kanas Pro it’s almost impossible to pick out in A/B listening. I ordered 3 more sets from Linsoul just to give to family and friends.Nothing like that. It works like a regular 2 pole 3.5mm
Hi. I'm still having trouble. I narrowed down the issue to isyncr synchronising to the SD Card. During diagnostics, I noticed some unusual behavior. When I take the microSD out, put it in an adapter and plug it into the SD card slot on my mac and it mounts, it only shows a LOST.DIR folder which is empty. Back in the R6 I see all the files. If I copy files to it on the mac those files cannot be seen on the R6. Is this typical?
Perhaps the SD card is faulty (it's a Sandisk Extreme 400GB), and if what I described above it's normal then either that is faulty or there is a problem with MTP on the device or a problem with the SD slot on the device.
Does anyone have a Hiby R6 and a Mac that can confirm what they see if they mount the SD card directly?
Sorry they haven't got back to me about this. I guess I owe you to say at least this much :/Hi Joe, any progress and solution pertaining to my previous query/issue. Please assist. Tq
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
Please tag or quote me if you have solution, currently I am using Hiby's USB DAC or coaxial output to external DAC to HIFI system.Sorry they haven't got back to me about this. I guess I owe you to say at least this much :/
Soooo I am experiencing issues with losing tracks now, too. I'm using a brand-new-for-this-DAP Samsung 256gb card. Everything was there initially, now it's not. Some tracks ARE listed but just don't play and get skipped. Since 90% of my collection is CD rips from the same hardware/software, there is either a problem with the SD card or player (fixable bug or otherwise)
Other note: Android File Transfer on my Mac suddenly doesn't display anything after the letter P (my folders are set up alphabetically by artists --> album)
I'm actively transferring the contents of the card with an external card reader (which sees, plays everything when plugged into my mac) and will re-format it within the R6 Pro. Then my collection will get transferred back.
Please look out for a firmware update to be released this or next week, addressing Bluetooth issues.Please tag or quote me if you have solution, currently I am using Hiby's USB DAC or coaxial output to external DAC to HIFI system.
By album folder do you mean an album in the album view or a folder in the Folder view that happens to contain an album?do anyone have an issue when the last file ack in the album folder not plays. but if you select it from the playlist is good. I have this few times in different folders. bery strange bug. Just wonder if it's just me.
