milesjunkie
- Sep 18, 2013
You could buy my AK70 instead hahahahahaI have the mojo and I wanted to buy a r3 to connect it, I saw that the r6 has the DTA for the bit-perfect and therefore I was interested.
Really? The difference is HUGE. This isn't a slight difference at all. It literally sounds like anything under 100 hz is totally absent. I didn't think there was that much processing going on.That is absolutely normal. When you are listening to native DSD - you hear the music as it was recorded. The R6 hardware has a slightly warm presentation (more bass) - but it can be done only in PCM mode. So when you are listening to in DSD mode the original R6 presentation is off.
Most DAPs use a much older Android version that still has USB Mass Storage mode. It’s been removed from AOSP for some time.
But as you said, not an issue because there’s an official (Google) solution.
Edit: the reason it was removed is because it effectively forces exclusive access to the storage device and thereby ‘unmounting’ it from the host device. That’s not desirable for a DAP because it will stop playback of music if you want to copy files to the drive.
Thank you, interesting to see this. So you have metal support for the backplate, you can use any soft thin material. Did you test how thick the material has to be to have flush result ?
So, I would up going the easy route. Got the miter case (which is really bad quality imho) and returned it, then bought the black Hiby R6 case. Yep. Just left the backplate off and didn't put anything there. Out of sight, out of mind and EASY access to the battery. I'm really surprised at how soft and nice the pleathure Hiby case is. It looks really nice, and I'm happy. Boring update, but that's what I ended up doing for now.
I wish those companies stop to copy the sh** that Apple did when released the Iphone 4 and stop to use glass in these gadgets.
If it's not sapphire glass, I am not interested.
Isn't the mojo a DAC amp. So I would have thought any player that outputs digital stream to the DAC in the mojo would do the job. I mean unlike CD transports there should be less variables for digital transports so to speak.I have the mojo and I wanted to buy a r3 to connect it, I saw that the r6 has the DTA for the bit-perfect and therefore I was interested.
Any player would. But here we are talking android and SRCIsn't the mojo a DAC amp. So I would have thought any player that outputs digital stream to the DAC in the mojo would do the job. I mean unlike CD transports there should be less variables for digital transports so to speak.
Miter case is a pile of steaming sh$t. I some times wonder if those Chinese manufacturers have a clandestine race to the bottom award.
in fact, I know that many dap can give the digital signal to the mojo but, r6 has the dta and avoids SRCAny player would. But here we are talking android and SRC
On the other hand digins also Korean is really good.
@superuser1 and @cirodts,in fact, I know that many dap can give the digital signal to the mojo but, r6 has the dta and avoids SRC
