KevP
- Sep 17, 2004
WiFi is generally appalling.
This looks excellent. And as I now find myself in need of EXACTLY the same remedy, a big thank you!Added a leather (maybe pleather) backing to my R6. Original owner cracked & chipped the lower right corner of the glass. I applied a layer of Bondic over it to prevent further chipping (I forgot to take pics). $10.99 for 5 7.8”x4” self adhesive patches - https://www.amazon.com/dp/B07CYKHBR9/ref=cm_sw_r_oth_api_6xY6BbFXVYGRT
It adds maybe 1mm to the overall thickness and you probably wouldn’t be able to fit it into the case, but I don’t use a case with mine and I think it adds some grip to the DAP.
I'm really disappointed in the inability of the R6 to mount as a drive on a mac, I get that android and apple aren't perfect bedfellows but neither are android and windows and there don't seem to be many problems there. I've had android daps that cost half as much as the r6 that mount as a drive and don't arbitrarily become corrupt. Hopefully the upcoming android update fixes this.
Other android DAPs can mount as a drive on Mac. So there....Hiby is behind in this regard. Really a moot point with 'android file transfer' which worked just fine for the R6. https://www.android.com/filetransfer/This is actually an issue with Apple not supporting the protocol used natively by AOSP (which the HiBy OS will be based off).
Most DAPs use a much older Android version that still has USB Mass Storage mode. It’s been removed from AOSP for some time.
But as you said, not an issue because there’s an official (Google) solution.
Edit: the reason it was removed is because it effectively forces exclusive access to the storage device and thereby ‘unmounting’ it from the host device. That’s not desirable for a DAP because it will stop playback of music if you want to copy files to the drive.
I had similar problems with my R6, but the issue was with SD card. I have replaced it by Samsung EVO card and now all is ok. Old SD card is working normally in other devices.With debugging enabled and the R6 in file transfer mode I still get random crashes and am often unable to write to my sd card. I've also had files disappear for no reason at all.
A card reader helps but using one usually messes with my tidal downloads and forces me to redownload them all.
You had problems with 'debugging mode' enabled and file transfers from a computer? Or you had problems with Tidal files needing to be re-downloaded? The solution was going with a samsung card, that was pretty clear, but hoping you can elaborate a bit on the problems you were having.I had similar problems with my R6, but the issue was with SD card.
I had problems with file transfers, but "debugging mode" was off.You had problems with 'debugging mode' enabled and file transfers from a computer? Or you had problems with Tidal files needing to be re-downloaded? The solution was going with a samsung card, that was pretty clear, but hoping you can elaborate a bit on the problems you were having.
