superuser1
Thanks, I just really want to get this that's all. I seem too eager at times.
From what I can gather that amp is rated at 10 ohms output impedance into a 1000 ohm load. This isn't the appropriate way to measure or spec it for a portable device. It should be measured into a 16 or 32 ohms load. I think the z out will measure much lower if that is done, just guessing but likely about 1 ohm. There is a fair amount of info about this amp in head-fi, consensus seems to be it sounds fantastic on high impedance cans, not so much on low impedance, but of course a lot will depend on implementation. Joe, I really would advise your engineers to measure the z out themselves into a load typical of IEM's, 16-32 ohms. I think you're doing yourself a disservice by just quoting the manufacturer spec, because it isn't appropriate for your application. This is similar to the mistake Shanling made when they first reported z out specs for their players.
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
I think the Z will remain higher than we want.
The series output resistor should be between 10Ω and 100Ω. The output series resistance eases the work of the output power stage by increasing the load when low impedance headphones are connected, as well as isolating any capacitance on the following traces and headphone cable.
The series output resistor should be kept at a minimum of 10Ω...
Starting with 1KΩ resistors for input and feedback, and 10Ω output resistance, the feedback resistance was lowered to increase the amount of current in the feedback network. The output resistance was increased to ease the load on the headphone amplifier when low impedance headphones are connected. Both of these additions contribute to the excellent SNR and THD of the TPA6120A2 in such a low voltage application...
...Using such a solution makes the TPA6120A2 transparent in the circuit, even into a low impedance 32Ohm load.
Regarding indiegogo, does anyone know if they charge you right away or once the campaign ends?
Should our impedance fears be realized, there will be many disappointed potential buyers - my self included. 32 ohm used to be low for IEMs, but not anymore, 12 ohms seems a better target.
Could this have been more thought out?
I'm hoping for flat response with my Andros, yet after reading the paper from the link reginalb provided, I have doubts.
Moving forward, can there be a low impedance version added?
