sikki-six
- Apr 5, 2007
f00fighters;5967356 said:Quote:
Originally Posted by mrarroyo /img/forum/go_quote.gif
Have you ever listened to your canamp with the Grado 325is?
Nope.
Nope.
No, only my RS-1 and it was not one of my favorite pairings.
sikki-six;5967360 said:Quote:
Originally Posted by f00fighters /img/forum/go_quote.gif
Nope.
That was not my question!
Originally Posted by carledwards /img/forum/go_quote.gif Just got one of these amps and initial impressions with the K701 is very positive for me. Love the tonal balance and clarity, especially from SACD. |
Originally Posted by blazarian /img/forum/go_quote.gif Hiya there fellow canamp owners. I have one question about this thing. I received the canamp today and have burned-in it like 3 hours by now and this thing runs hotttttt. Is this normal and is there any known issues considering this thing? The volume knob almost burns my hands. Thanks! - blaz |
Originally Posted by El Cucuy /img/forum/go_quote.gif The CanAmp runs in Class A mode all the time. That is to say that from the moment you turn it on, it's going full tilt, only being limited by the volume control. What effort that is not being required of it is being dissipated in heat. This is normal of SET (Single Ended Triode) Tube amps and Class A operation Stereo amps. While I'm sure the volume control is unusually warm, it won't burn your fingers. The case can get hot and, like the heat sinks on big class A amps, you'd think twice about leaving your hand on them, they still won't get so hot as to leave a burn mark on you. Just uncomfortably hot. Give it good ventilation and it will serve you well for a long time. On a side note, break-in really does take quite a bit, more like 200 hours and it will turn a corner, breaking in. |
Originally Posted by blazarian /img/forum/go_quote.gif One more stupid question. So the amp keeps heating and is hot all the time if it is turned on altho no audio is played thru or volume is turned to zero? ;< So I have to turn it off from the backpanel to make it not to produce heat? |
Originally Posted by blazarian /img/forum/go_quote.gif So it is fine to keep it ON 24/7 without a worry of heat causing damage to the unit? |
Originally Posted by loopfreak /img/forum/go_quote.gif Would heed canamp justify the upgrade and money spent or should I buy headphones with warm sound because I already own senn hd 25 1 with dark in your face sound , 702 with smooth , big sounstage ? |
