dw6928
- Apr 13, 2005
well thanks, I have learned a great deal about hard drives. I appreciate it.
Originally Posted by dw6928 /img/forum/go_quote.gif there is a school of thought that believes that there is much less wear and tear on your hard drive if you leave it running as opposed to the wear caused by start up and shut down. this happens to be a large group that believes this. |
Originally Posted by daggerlee /img/forum/go_quote.gif d-cee, the large power thump you get when you turn it on and off is related to the DC offset. as I have noted time and time again the NE5532 produces very high levels of DC offset, around 30-35 mA (the DIY community considers 20 mA to be the absolute maximum safestl evel, although other people say 50 mA is the limit) since the new opamps you use have much lower DC offset the thump will be lower.... |
Originally Posted by yrh0413 /img/forum/go_quote.gif 1. 16v 4700uF Jamicon caps planned replacement: Nichicon FX 10,000uF 16V 2. 35v 100uF Jamicon caps planned replacement: 100uF Elna Silmic II 3. 63v 10uF Jamicon caps planned replacement: 10uF Elna Silmic II Questions: 1. Will the Nichicon FX series be an overkill? How is it if i get the Elna Slimic II 4,700uF 16V instead? 2. What's the minimum voltage rating required for caps 2 & 3? |
Originally Posted by d-cee /img/forum/go_quote.gif i'd replace all caps with new ones at least rated as high as what's in there now. with the big power caps, you can probably try fitting in 22,000uF 16v caps would work |
Originally Posted by yrh0413 /img/forum/go_quote.gif d-cee, is this list ok? (2) Panasonic TSHA Al electrolytic cap,10000uF 16V (2) Elna Silmic II 10uF 25V (2) Elna Silmic II 100uF 35V (4) Rectifier diode,MUR820 8A 200V (4) Rectifier diode,UF4002 1A 100V (6) PHE426 radial polyprop cap,470nF 250Vdc Questions: Quoted in red: Which is better? The MUR820s are slightly more expensive than the UF4002. From the specification sheet it seems that the 820s have faster recovery time than the UF4002s. I notice there are 7 white film caps on the stock board, but why is everyone replacing 6 out of 7? In your mod list i notice you swapped 6 470nF polypropylene (which white film cap that you didn't swap out?) Thanks! |
Originally Posted by d-cee /img/forum/go_quote.gif i'm not sure about the diodes to be honest, if it has faster recovery time i imagine that is the better if all else being equal. but i am not too familiar with diodes and how their specs affect the sound. as for your choice in polyprop caps, theyre the same as the ones i use, however they are huge! and are a pain in the ***** to install, all of mine are mounted under the board and in various locations further down the track than in their original holes, i strongly suggest getting smaller caps. i replaced all the film caps on my canamp with these polyprops the rest of the caps looks fine but i still reckon you should get 22,000uF/16v or 10,000uF/35v caps ![]() edit: oh and don't forget about the DIP-8 socket and some browndogs for easy opamp rolling! |
Originally Posted by jeremiah /img/forum/go_quote.gif Hi guys, I've been away for quite a while, been busy with work and all. Managed to wire the funds to Alpar just now, hopefully my CanAmp can be shipped out soon, can't wait can't wait!! ![]() I'll be going with output from an Auzen X-Meridian to CanAmp then k701 if that information is any helpful (which I doubt is,haha). Any particular cable that would work well to connect my soundcard to the amp? I heard a saying that a bad interconnect can jeopordize the whole system! Talk about the weakest link...hehe. I hope that's not true, at least for me, cause I certainly have no idea what is good! Heard about Canare and something Musical Bluey thing and all, well, i'm all ears now so throw out your best! |
Originally Posted by pinkfloyd Never go under with cap voltage rating.... ok to go higher but only up to the next voltage rating (with an electrolytic) Best thing to do is measure the voltage across the existing caps (probe across the pads with your voltmeter set on the DC scale) If it's 26V then go with 35V not 25V if it's less than 25V then go with 25V caps. |
Originally Posted by Blackbird Audio /img/forum/go_quote.gif I'm still of the opinion to leave the amp on all the time. This way you don't have to wait for it to get to operating temperature, where it will sound its best. When you're ready, it's ready for you! Just turn the volume all the way down and/or unplug the cans in case of something big getting on the line such as a lightning strike, so you don't loose the cans too. There are good after market power filters that will offer spike protection for such an apllication. Some even have insurance to replace your devices should they get damaged by a spike when using their products. Just listen to be sure they don't restrict the amp's current draw when you run it with one of them. |
Originally Posted by daggerlee /img/forum/go_quote.gif d-cee, the large power thump you get when you turn it on and off is related to the DC offset. as I have noted time and time again the NE5532 produces very high levels of DC offset, around 30-35 mA (the DIY community considers 20 mA to be the absolute maximum safestl evel, although other people say 50 mA is the limit) since the new opamps you use have much lower DC offset the thump will be lower... |
Originally Posted by yrh0413 /img/forum/go_quote.gif anyone knows what are the voltage ratings for the 10uF and 100uF caps? Thanks in advance ![]() |
