High_Q
- Mar 20, 2010
HD650 destroys sibilance.
I think there's a bit more to lack of colouration (yay Canada) than just a relatively flat frequency response. I've had quite a few cans with a relatively flat frequency response, and they all sound completely different:
Charteroak SP-1 (detailed, delicate, fast)
Pro 750 (cold, analytical, snappy)
Pioneer Monitor 10 (indescribable)
Beyer DT480 (crystal clear, smooth, peppy)
Fostex T50RP (warm, smooth, almost detached from the music)
Beyond frequency response, I think we find neutrality in what fits our hearing the best. If you are able to, I'd recommend listening to a few pairs of relatively neutral headphones with music that you're very familiar with. You should be able to settle into a pair that sounds just right to you.
In terms of headphones that can be really revealing about the source--that's a dangerous game to play. A lot of songs these days are mastered not to sound perfect to the band and producer, but to sound decent when heavily compressed and played on the radio. The more revealing headphones become, the more painful that music gets.
Before you start seeking out the most accurate headphones you can find, here's a quick test for you to take on. Get yourself a copy of Foobar if you don't have it, then set up a peak meter. Play a song from your ten favourite albums. Watch for albums that have been heavily compressed (you'll know because they will sit at the peak (0db) line pretty much the whole song. If most of your music is compressed, you might not want too much of a clear window into what the recording really sounds like.
While I haven't got my pair of DT48 in yet, the 480 is remarkably revealing. You hear things like the piano bench squeaking, to an extent I haven't heard anywhere else. That said, you might be quite happy with the Pro 750 once they are Kees modded, as long as you like that cold, clinical sound. If you get an amp that can feed them properly, the Fostex T50RP is a pretty good introduction to the studio sound, with that warmth that makes them a bit more forgiving with bad recordings.
Sonic Atrocity said:
You jerk!You totally threw a wrench into my train of thought. Seriously though, thank you! I appreciate the insight. All of my music is lossless ALAC (converted from FLAC). So, as for the Foobar/peakmeter test I don't know if that will work (will it?). As for producers/artists making recordings that are intended to be listened to in a compressed format (ie: for radio play)... is that usually just with bad pop music? Would this apply to say... NIN, and Radiohead? I'd hope not. I also listen to some underground metal and whatnot. So, I am hoping that I can at least find fidelity there.
EYEdROP said:
It's our duty.
Just as lejaz said, it's how human hearing works. Our ears are less sensitive to bass frequencies at lower volumes, so you may want to compensate for that. I can't say if an amp is really required; I'm very happy with my 8 Ohm DT 48 unamped, but I don't have an amp to refer to.
Yes, you can still do the peak meter test. The kind of compression which that test will reveal is compression of the audio signal that's done in the studio. That is very different from the compression of the digital file to make an mp3. The best music to judge the 'neutrality'/flatness of a headphone is classical or acoustic jazz, IMO. They won't be overly compressed in the studio. Plus, if you listen to acoustic instruments you can judge how well the tonality and timbre is reproduced. In other words, how well a headphone reproduces the sound of an acoustic piano, trumpet, etc. With electronic instruments you are pretty much in the dark.
oops, I see I forgot to update my signature with the dt48....and I'm a card carrying member of the dt48 fan club. My apologies to the other charter members
I have both the 480 & DT48.. The 480 is more musical for sure.. The DT48 more detailed & resolving by a good margin, depending on the era & type of DT48.. Both mid ranges are very good, but the DT48 is a level above it..Could just be preference..
Hmm, I am not familiar with the studio compression that you speak of. I think I have an idea as to what it may be. Would you mind explaining it to me, please?
I'm not trying to say otherwise--I'm just still waiting for my DT48 to arrive, and the 480 is pretty darn neutral as well. My opinion could change dramatically early next week. I won't know what my preference is until I can compare them.
A lot of headphones boost the bass, because most people have come to expect to hear the bass overemphasized these days.
And most "flat sounding" headphones remove bass and add treble so they sound "clear". People have to ask for "flat" and "not sibilant" in the same sentence because head-fi's notion of flat has gotten very confused with "clarity" over the years.
It depends what kind of live event you attend. You get chest-thumping bass at a lot of rock concerts because the bass has been boosted. You get the low notes without a thump with classical and acoustic jazz. You hear the low notes, but no thump. Some headphones get that right and some add to the bass. I disagree that all of the neutral headphones attenuate bass - some years ago, someone demonstrated that the K-501 reproduces all the way down.
