2deadeyes
- Mar 18, 2005
In.
Silver chassis w/black bezel (Silver knob possible?)
With DAC
3 feet USB cable
With DAC
3 feet USB cable
Originally Posted by atomiccow /img/forum/go_quote.gif Can the Pico function as a DAC alone? As in can you bypass the headphone amp inside and plug it into a home headphone amp? Can the Pico sufficiently drive an HD650 and K701? Not drive as in simply cause them to make sound but actually cause them to make good sound. I've heard numerous times that a Hornet will drive a K701 and I for sure can say that my Hornet definitely does NOT drive a K701 on any gain setting. |
Stay updated on HeadAmp at their sponsor profile on Head-Fi.
Originally Posted by Andrew_WOT /img/forum/go_quote.gif If no special request is made, will knob color match the case. E.g. if clear specified on preorder, will the knob be clear too? And is red the only LED option? Thanks |
Originally Posted by justin w. /img/forum/go_quote.gif - You can't bypass the headphone amp, you can only use the output as a volume controlled "variable output" which is very transparent when connected to another amplifier |
Originally Posted by Andrew_WOT /img/forum/go_quote.gif Justin, what gain and volume position would you recommend when connecting to external amp? I assume gain should be at low, should the volume be maxed? |
Originally Posted by Iron_Dreamer /img/forum/go_quote.gif The silver on black looks great, Ed! If not for loving the bronze finish ever since I first saw it on an AE-2 (aside from how it mimics the L3000's color), that would have to be my color pick! |
Originally Posted by nickknutson /img/forum/go_quote.gif Has anyone tried their Pico with a pair of SR225's? |
