Kwisatz
- Oct 12, 2004
He occasionally does long gaming sessions, but he's pretty tolerant about a reasonable level of discomfort so I don't think headphone weight will be a disqualifier. It was mainly the clamping pressure that concerned me.
Some people complain about the weight, but I don't find the weight to be a factor at all. I never forget they're on my head, but I've never had any discomfort from the weight even during extended wearing. Unless he's particularly weak necked, I doubt he'd have any problem with the weight. If he has done any motorsports that require a helmet, he definitely won't care about the weight. The weight of the LCD-2's is nothing compared to putting a helmet on your head that weighs multiple times as much. (Granted the helmet's weight is distributed across more surface area, but that won't make any difference to the neck, and the headphones don't have to deal with g-forces increasing the load.)
Clamping pressure wise, it's a springy metal band creating the pressure, so he can always stretch the headband out to reduce it. I haven't done it myself, but others have claimed it helps. Similarly, the band should naturally lose a bit of it's tension simply from every day use over the course of time. Also, the body itself is amazingly adaptable. Everybody is different in how quickly they acclimate, but the body will eventually adjust to not being bothered by what was originally uncomfortable. Mind you, that isn't an excuse to keep something that is found extremely uncomfortable. However, if he ends up really enjoying the sound, but finds them a slight bit uncomfortable, then it's probably better to keep them and adapt than send them back and gamble on a different sound signature in the HE-500's.
