robrob
- Jul 10, 2013
Thank you. Just the keyword I was looking for. Why should it be 5 way, aren't other types of binding posts fine?
5-way's are common, inexpensive and very flexible.
Install both TRS and XLR jacks just for the cool factor Or maybe a 1/8", 1/4" and XLR jack.
Mouahahahaha, I love this. Since the grounds are already connected in the amp I wouldn't even need a switch or anything, no downside to daisy chaining the plugs?
Just make sure you only have one thing connected at a time, or you risk letting the magic smoke out!
If using TRS, be careful plugging/unplugging as you will make a temporary short if done while the unit is on.
Do I have to power down the unit before inserting/removing TRS phones?
Having been inside the amp, does this look like it would work?
Nope!
The XLR and 1/4 would be fine. The 1/8" is not going to work! There's a board behind (screwed) the front panel.
You could however move the 1/8" to the right side.
New "prototype" haha
was just looking at that, will probably stick with these, symmetrically one on each side.
http://www.neutrik.com/en/audio/plugs-and-jacks/locking-1/4-chassis-jacks/nj3fp6c-b
http://www.neutrik.com/en/xlr/dlx-series/nc4fd-lx-b
The load would be too big or something if I have 2 plugged in at the same time? I don't like the idea of that hapening... even by accident ... by a friend/guest whatever... any way to make sure no permanent damage happens if I accidentally plug both?
