TMRaven
- Apr 6, 2011
You might be able to get an audio gd nfb12 at that price, or o2+odac.
thanks, and do you know if the e11+HRT MusicStreamer II is a good setup for it? I already own the e11 so I was planning on buying the 150 dollar HRT MusicStreamer as a DAC
There are other choices and options for the budget you have for your upstream setup, but just the setup you are proposing should be able to perform admirably with HE400s; these cans are incredibly forgiving in terms of amping, and sounds great out of even most entry-level setups assuming you can drive it loud enough (it's quite efficient so that shouldn't be an issue). It does scale very well too though so there's lots of incentive for upgrading the setup in the future.
If you have the budget for it, get the odac. People say it's better than the music streamer, and performs well above its price.
Many people on head-fi say the hd600 sounds laid back, do you think the NFB12 made it a bit less laid back or do you think the hd600 isn't laid back at all? Do you think its more exciting and sounds more alive than the he-400?
I've had HD598, HD600, HD650 and SRH1440, 've been testing them for some time at home, DAC/preamp - NFB12.1
You will not get bored with HD600... never. It's just ********. They sounds one level better, than HD598. I didn't heard many tones, that I've heard on HD600, and they gave me much more chills. They are pretty balanced, but for my taste, have little bit more hights and brightness. I think, it can be EQ down. Their basses are nice, strong, punchy, for me, it's plus, it gives really power in tracks, especially rock.
HD650 are more warm, dark, their lows roll... it makes mids and highs to less shine. I don't like this aspect. Well, another point is, they need very good amp, to get all from them. Count 500$ and more. HD600 are little less demanding, but don't get anything under $250 with good power amp. I've tried them on onboard sound, and it just cannot match NFB12. In other way, HD598 has sounded out of the onboard still pleasing... the drop out in quality was not so big, as in HD600/HD650.
Now, to the SRH1440... they are bright. They mids are like highlighted, highs are very nice, but it's very bright. Not as DT880 (i'm speaking of highs), but I would say, very close. SRH1440 are very weak in bass. (less than DT880, I would say, around the same as K701 - Q701) They have nice basses, detailed, but punch and energy is missing in drums. Not even match HD600. This is reason, why I don't like them... when I am listening to rock and fast metal - HD600 - energy SRH1440 - almost no energy.
But there's a mod... dalethorn mod, that should lessen brightness a little, and help basses. They should sound closer to SRH 1840. Didn't tried it yet, but if that's true, then SRH1440 can be really better than HD600 with this mod, except basses. Basses can be EQ up a little, but they just cannot play that "precise punch with impact (from HD600)", it's just missing. Maybe they need even better amp? Don't know.
It's been a while since you posted this but I had a question. You seem to kind of understand what setups work well with the hd600, do you think the schiit asgard and the HRT MusicStreamer II would be a good setup to use with the hd600?
HE-400s fit your bill great. I also have (well...had) the M50's and the upgrade was perfect in every way. The planar sound (characteristically flat extremely well extended and clean bass, very real timbre, great 3D imaging, insane details across the entire frequency range) at only $400 is a great bargain. With the newest revision drivers and velour pads they are fantastically well-balanced from bass to treble, really alive and "fun" sound that is also very accurate.
If however you care about mids and a "smooth" sound more than details / imaging / dynamic aspects of sound, then HD650s are more for you; doesn't look like that's your sole priority though.
^^this is dead on^^
My top priority is forward mids and smooth treble, does the he-400 have that?
