Thanks for the idea. I should have tried that when I first got them. They didn't bother me too much but the pads did touch my ears. I think I didn't always get a perfect seal.
If anyone is interested in modding them, I've tried a few things so far..
A month ago I tried some blu-tack inside the cup. I really loaded it up and covered every area, but only one layer. It really improves the bass a LOT (but not in quantity), but it makes the mids even more forward. I'm not sure how or why this is. Some may like it, but they were much more fatiguing. After a month I decided to reverse it or try other things. The bass was worth the forward mids I think. Mids perhaps even more forward than the ATH-AD2000 and MV1 (which I didn't like).
This time I removed all the blu-tack and used Akasa Foam. It's very thin and I used it to cover only the round center of the cup inside. On the first attempt I covered the inside circle and "ledges". This seemed to offer similar results to the Blu-Tack, but this time the mids were a tiny bit less forward. Maybe not, but that's what my ears heard. Somehow the soundstage didn't seem as good somehow.
I opened it up and removed all the foam on the ledges and just kept the Akasa foam on the inner circle. I made sure to cover everything.
The sound seems to be improved and the bass is slightly better. Mids may be a tad more forward, but again I don't know how this could be possible. For me there was a big enough improvement to keep the foam installed. I just know that right now they sound perfect.
I might try putting some material around the ledges that's super thin and see if it doesn't screw up the soundstage. Above the ledges there are fabric covered holes and go into the outside of the cup. Don't mess with those holes whatever you do! Another idea is only putting Akasa foam in the circle and only in two areas of the ledges instead of all 3.
If anyone tries any of this, take extreme care with those wires!!! I've already killed one pair of DJ100's 6 months ago! I even blew up the driver! All my fault. I had to fork over another $80. Second pair needed 3 days of burn-in when my first needed zero.
I've found out that for these mods, the Tron soundtrack is good for testing
The thicker Blu-Tack had the biggest improvement of the bass.
The best reference track I've found is Utada Hikaru's "Final Distance" on her Deep River CD (not for bass). Japanese pop is just so good on these headphones. The sound quality on some of her songs with these headphones gives me goose bumps. Weird, I know.
A weird thing I've noticed is that often I heard a song and think "This doesn't sound too good" and it turns out to just be the song. I keep trying to blame the headphone. I still can't figure out why anyone would think these don't have enough treble. To my ears they have more treble than my DT-880?!
I'd like to find a closed headphone under $200 with a better soundstage. Ok, it's not comparable to a very good open headphone in this area, but still quite good for a closed and small headphone.
Still listen to these things every day. Kind of addicting. I can't wait to see what an open headphone with this driver sounds like. Not even sure if it's possible. Hopefully someday I can find some type of memory foam pads for these, but that probably will never happen. The V6 pads are comfortable, but I'm sure there is something even better out there.
EDIT: Haha, nobody probably cares, but I almost just nearly killed my DJ100 for a second time. I was screwing my DJ100 up (pun intended) and my hand slipped and the screw went flying into the driver and stuck to it due to it's magnet. Nice one! So there I am trying to fish this screw out. If I was smart I would have just gotten my lazy butt up and got the tweezers. So then I turn it on and ZERO sound on one side! I open it up and somehow I ripped out one of the cables. Luckily my soldering iron fixed that in a few seconds. Problem solved. So glad I didn't kill the driver.
So what did I do this time? I kept the Akasa foam in the inner circle and added very thin blu-tack to the "ledges". I then took the bottom of a sharpie and completely flattened out the blu-tack and made a bunch of indentations to make it as thin as possible.
I'm glad to say that the mids are now more forward than before but now not as forward as before (with ALL blu-tack) and not enough to cause ear fatigue (for me). The bass with the Akasa foam and the blu-tack is now as good as it gets. I'm testing it now, but it seems like this is what works the best so far. With only the foam in the middle and no blu-tack, the bass just wasn't as good as when I had everything covered with Blu-Tack, but the disadvantage of that was the mids were too forward and the headphone was just too shouty and kind of fatiguing.
BTW I've been listening to these for a long time now with the two new updates. The results are just so unbelievably good. I'm shocked really why and how some simple foam and blu-tack could make that much of a difference. It seems to be effecting so many things in the sound signature. On one song I've listened to for years, I've heard some tiny details at the start of the song I've never realized were there until now. Female vocals are just now so much better. Zero change in the treble somehow, but that's OK. I'm thinking of buying another pair and recabling it. I don't want to sacrifice this pair if I screw something up. I think adding a MUCH thinner layer of Blu-tack and making tiny indentations in it are what made the difference. Some songs almost sound totally different and I'm not exaggerating. With the thinner Blu-tack the soundstage no longer seems to suffer either.
