Not in the foreseeable future. No enough room for the genV board as it is, right now.
Might be possible down the line, if smaller components are made/found.
+1Eitr. Significant difference in sound. Relatively minor cost to get such a significant upgrade in sound and keep a neat small stack. My understanding is that gen 5 will not fit in the mimby box.I’ve had my Mimby for about a week now, leaving it on 24/7 except when I unplug it to try it in a different room. It sounds great playing through speakers, but still pretty harsh and fatiguing when I listen through headphones, especially using USB as a source. Based on what I’m reading here, others have had a similar experience: Those using a coaxial source and listening through speakers seem to love the Mimby, but those using the USB input often find it sub-par, perhaps especially when listening through headphones
Unfortunately the whole reason I bought it was to use as a USB DAC for headphone listening. Specifically, I want to play Tidal from my iPhone into my Vali 2 feeding my Open Alpha headphones (DIY Alpha Dogs based on mrSpeakers plans). Occasionally I would connect it to a Raspberry Pi or a laptop, but usually to the iPhone. It would be taking the place of a Dragonfly Red (which actually pairs really well with the Vali 2).
If I’m primarily using an iPhone as the source, should I just send the Mimby back and look elsewhere? Would an AQ Jitterbug make a significant difference? It’s really hard for me to see spending another $100-$200 on a USB-to-coaxial converter or USB power supply. If it takes that kind of additional cost and complexity to make it sound good with USB, shouldn’t I be looking for a different DAC? I was really excited to have a nice neat Schiit stack, but if I’m spending that much, should I be looking at a Mojo instead? Or one of those Chinese XMOS DACs and a better tube for the Vali 2? I’m looking for a DAC that is a noticeable step up from the Dragonfly Red, but I’m going for an enjoyable, non-fatiguing presentation, not analytical and super-revealing.
(I apologize if this has been asked before. I read the most recent 600 or so posts in this thread, but with only a 15 day return period, I’m running out of time to make a decision.)
A few pages back Mike Moffat said something along the lines of 'nope'. I could be wrong, but I believe that there was no way to fit the USB5 interface into the Modi chasis.I assume Mimby will be updated with USB5 in the future?
How can you feed it with a 5V PSU? It uses like 15VAC? Did you open it up and bypass the internal PSU or something?I'm certainly no fanboy and I thought Modi1 & Vali sounded horrendous, stock Mimby was also too bright but with a bigger wallwart and a clean 5V PSU Mimby is amazing. It's meant to be a cheaper Bimby so provide it with bigger/cleaner PSU's and bang/bucks will go up through the roof IME.
That’s a separate (additional) 5v PSU for the USB receiver chip, if I’m understanding him correctly.How can you feed it with a 5V PSU? It uses like 15VAC? Did you open it up and bypass the internal PSU or something?
I would like to learn more about this.I'm certainly no fanboy and I thought Modi1 & Vali sounded horrendous, stock Mimby was also too bright but with a bigger wallwart and a clean 5V PSU Mimby is amazing. It's meant to be a cheaper Bimby so provide it with bigger/cleaner PSU's and bang/bucks will go up through the roof IME.
Cleaner power for the USB receiver, I think that he meant.How can you feed it with a 5V PSU? It uses like 15VAC? Did you open it up and bypass the internal PSU or something?
would the Floor Wart be considered a bigger wall wart?
Is Vali2 a good partner to the Massdrop HD6xx (especially for female vocal) ?
