harry501501
Zen DAC, have the stack.
Funny you say that, I nearly bought v1 thinking the price had come down or it was on sale on Amazon... then saw the v2 lol
I have to say that I'm starting to appreciate the XBass and 3D features when used at lower to moderate volume levels. At higher volumes they can be a bit much, but at moderate to lower volumes they seem to work really well.
Enjoy- I have had this for about 4 months and it’s a winner- it’s main attraction to me connectivity-wise is that it has 3.5 mm and 4.4 mm INPUTS, which is unique (as far as I am aware) in this price segment. Most amps with balanced inputs use XLR. The Cayin C9 also has these same inputs (for about 10x the price). BTW - it may be worth checking out the review for that elsewhere on this forum, especially that by @twister6, which can also be found at https://twister6.com/2021/02/26/cayin-c9/. About half way thru he does some comparisons of 4.4 mm inter-connects that is worth reading (especially if you believe that cables can affect SQ).Just picked up a Zen Can. What a great affordable little amp. Even straight out of the box it's sounding pretty nice, and I guess it will only get better. The version I got came with a generic-looking wall wart so I've ordered an iPowerX. Not sure if the extra expense is worth it or not (it's about 75% the price of the Zen Can itself), but figure I'll be keeping it for some time and might as well try and milk all the performance I can from it.
I've previously had the rHead, which was nice but the overall tonality/speed wasn't quite my cup of tea. I also (briefly) had a Fidelice headphone amp, although returned it due to high-pitched ringing which seemed to be a power filtering issue. Not sure how that issue would affect the sound signature but it seemed pretty harsh and a little too punchy to be honest.
I've got a 4.4mm to 4.4mm cable on the way; interested to use the Zen Can with a Plenue L (as the balanced out has quite a different signature), then I can run my single-ended wired B&W P7s in combo with the PL/Can combo.
This sounds like a product defect, suggest to open a trouble ticket with IFIMy zen dac signature started having noise 4 months since I bought it. The noise sounds like the popping noise on old vinyl or scratched CD. I tried the dac on both my laptop and my PC and the noise was still there (though it was smaller on my PC). My dongle and Schiit dac work flawlessly so I don’t think the USB ports on my laptop and my PC are broken. What should I do? I found IFI has been selling some noise-cancellation products such as Idefender, Isilencer..but I don’t know if they works on my case. Anyone here has that noise problem with Zen dac sig?
Tks for your rep. After many hours trying many change (cable, software settings..) I found out a solution for the problem. That is lowering the latency's value on Buffer setting tab in Ifi HD usb control app to "standard" or lesser value ( I had set it to minimum latency so that the popping noise occurredThis sounds like a product defect, suggest to open a trouble ticket with IFI
Is it ok to plug in 2 headphones at the same time ? One is 250 ohm(SE) and the other one is 25 ohm(bal).
I would get the Zen-Can as you already have a good Dac that you can connect to the Zen-Can amp with a Balanced interconnect.I’m currently looking to upgrade my setup for my Hd600. im using a 4.4mm balanced dongle out from my laptop. What Would be more beneficial? Getting the ifi zen can to use with the 4.4 dongle or get the ifi zen dac first then pickup the CAN later on? I can only get either one at the moment
What is the dongle?I’m currently looking to upgrade my setup for my Hd600. im using a 4.4mm balanced dongle out from my laptop. What Would be more beneficial? Getting the ifi zen can to use with the 4.4 dongle or get the ifi zen dac first then pickup the CAN later on? I can only get either one at the moment
