blomman77
- Dec 30, 2011
Me too!
Took the bait!!
Took the bait!!
Will do. Usually takes about 2 weeks from there to here.Let us know how they are!
you are correct, 3-5h refers to the running time of the earpieces themselves. The other possible reason for the short running time is the small battery capacity on the earpieces: 30mA. I remember seeing 50mA for some other TWSes.
just trying to guess what is what. 3-5h? Which does not seem very impressive, but maybe powering those 10 units takes extra power?
Apparently it have 3 different colour.
These look very compelling. $43 with $2 coupon from AE right now. I'll probably wait for some feedback, because returning is a Beeeaaatch.All about the KZ but TRN has this one, T200...
Anyone order??
these look like hearing aids...
and i want them now! the 3-5hr battery life doesn't sound very good though, damn.
10 drivers takes some juice to drive. Sound was clearly a priority over max battery life.
Maybe some day we’ll have graphene batteries or even tiny fission batteries that last indefinitely. Until then, 3-5 hours is going to have to be good enough lol
For what they are, I think they look pretty sleek. 3 to 5 hours is a pretty wide range, likely due to the number of drivers, so each volume adjustment will affect battery by a greater factor than a standard single DD. That being said, the opposite is true as well, so if you're listening to them around 40% or less, I'd venture to guess you'd be on the 5 hours side.these look like hearing aids...
According to https://raingrande.com/hashtag/kze10 it's 5 drivers per side10 drivers takes some juice to drive. Sound was clearly a priority over max battery life.
Sounds like just fitting everything in was the deal. No reason to put 30mah in there. They just had to get to that "10" number cause driver count is what sells for them.
Yea its 5 drivers per side hence 10 drivers total.According to https://raingrande.com/hashtag/kze10 it's 5 drivers per side
I love my Tiso's! and Tips make a big difference for me. Wide boar like the JVC spinfits work best to separate some of that mid bass to sub bass in the Tiso.Thanks, yes I'm quite happy with the Anbes 359 although I'm still experimenting with tips. Right now I'm using the old Sony+Foam tips and they isolate very well but can "plug" my ears depending on the way I insert them. I'll give the Tiso i4 a pass then !
