Going fully Wireless IEMs. Too soon? Or are we there yet?
Jul 26, 2019 at 9:36 PM Post #9,721 of 62,271
The guy doesn't want to comment on the sound since it's not the final version. But the eartips included are very soft and comfortable. The earbuds fit very secure and comfortable. A single tap plays and pauses. 3 taps on the left side is volume up, 3 taps on the right side is volume down. Think all the other information is available via internet print, 3 hours run time, etc.
So is the version everyone recently ordered the “final version”?
Jul 26, 2019 at 9:58 PM Post #9,723 of 62,271
I got mine too, I was too lazy to take pics, so thanks. I would say that their saving grace is aptX. They sound much better with aptX, but I only have two devices that support it, none of them portable. My volume via iphone xs max is great. but you're right they aren't outstanding. They have the same voice assistant as the mpow T5 but the function much less quirky. My T5's have to power off one ear at a time for some reason, the BB's don't.
That would track with the EQ35 back bay I had. aptX on my Sony S45 made them sing pretty nice. Don't think I have anything with aptX right now either. Still, have gotten these BB to sound quite good with these...
The Apple in-ears style tips. I am using the large which is pretty big so it kinda has a little rub going in and out of the case but not that bad. I noticed that all the tips are on the small side which I am sure contributes to the lower bass amount. Anyhow, much happier now with the SQ. Of course that is the same as my last Backbay experience; the stocks tips weren't gonna get me to the best SQ. Working with them is recommended to get the best sound out of them.
Jul 26, 2019 at 10:28 PM Post #9,724 of 62,271
Not touching kZ with a 10 foot pole
Jul 26, 2019 at 11:02 PM Post #9,725 of 62,271
Jul 26, 2019 at 11:18 PM Post #9,727 of 62,271
Anyone have trouble getting both sides of the Trn BT20 to pair with an iPhone? It was working great for awhile, and now it will only allow one IEM to work at a time.
Jul 26, 2019 at 11:38 PM Post #9,728 of 62,271
when turning on both the L and R side at the same time, hold them close to each other (5cm approximately). if you turn them on while wearing it on the ears, for instance, they won't pair to each other because they're too far away or the pairing signal is blocked by the head.
Jul 26, 2019 at 11:40 PM Post #9,729 of 62,271
Jul 26, 2019 at 11:51 PM Post #9,730 of 62,271
Jul 26, 2019 at 11:53 PM Post #9,731 of 62,271
Oh that totally worked! Thanks!
Jul 26, 2019 at 11:54 PM Post #9,732 of 62,271
Jul 27, 2019 at 12:11 AM Post #9,733 of 62,271
Fostex TM2 and Andromeda playing AAC through Iphone has sound made in heaven. HUGE soundstage, HUGE bass, mids and highs are perfect.
The only problem is white noise on quite tracks. Maybe, because Andromedas have armature drivers. Fostex stock IEMs with dynamic drivers don't have that much noise.
They sound really bad compare to Andros.
Glad I'm not the only one who's had that problem. With sensitive IEMs like my FitEar 335s, I hear a considerable amount of white noise. The controls are also super loud when they connect/disconnect. Is it possible to change that?
Jul 27, 2019 at 12:25 AM Post #9,734 of 62,271
glad to help! it also gave me the same headache when i first got it, until i found the way to do it
