nc8000
Jabra 65t also has this. And you can config transparency level via the app
And Beoplay E8 and Earin M2
Anyone hear about the Earin M3 release date? Or any info on it. I will be definitely purchase these when they come available.
Interesting...seems to tick off most boxes.
If it were 8-10 hr battery/APTX then it'd be worth it especially at that price.Interesting...seems to tick off most boxes.
I like the look of those. Reminds me of the X12 style. No APTX, but at least battery is rated at 7hrs(I'm sure at 50% volume). If they were $50 I'd probably try them out.
Definitely looks very compelling for the price. They basically look to be the same as these guys: https://www.amazon.com/KNZ-Technology-KNZSNDFLXBLK-Dual-Driver-Headphones/dp/B07JN92X1C/FWIW, my daily driver these days is the Syllable S101, which can be had via AliExpress for about $30. They have aptX, AAC, IPX6, 7-10 hours of battery life on the bud (depending, I suppose, on if your source is BT 5.0), another five? or so charges in the case, dual drivers (a first, I think, for totally wireless buds), better than average outgoing call quality (apparently there are four mics that, as with the Jabras, help reduce outgoing background noise during calls), and a reliable connection (at least with the iPhone XS). The form factor is a bit strange, but they fit wonderfully with great isolation — and, most importantly, they sound wonderful to my ears.
For comparison, I also have the Sennheiser MTWs, the Jabra 65ts, the RHA TrueConnects, the Anbes 369s, and the MPOW T5s — but the Syllables are the ones I reach for most often. I just bought (and returned) the Powerbeats Pros — they just didn’t fit my right ear (I tried every tip I have), and since the tips are supposed to sit toward the outside of your ear canal, they provide barely any more isolation than the AirPods. Since I would have been using them on the subway every morning, they just didn’t work for me. Very disappointing, because the feature set is cool, and they sounded terrific in a quiet room (for about 10 minutes, until my right ear would start to hurt).
How's the latency? Some reviews on Amazon indicate it's not very good. Any case drain issues (earbuds turn themselves on when the case loses charge)? Have you confirmed aptX and AAC? Some Chi-Fi indicate they have one or the other, but they don't. Since I have Android devices sitting around here (LG G6, Galaxy s8), I check the codec in Developer Options.
how's the S101 sound compared to your other TWS? also would you mind taking a picture of it while on the ear? I'm curious about how much it would stick out.
