BobJS
Do they support aptX or AAC?
Someone who owns it on Reddit claims it supports AAC.
For a while now I've wondered what Codec my BT20's were using with my old Samsung Note 4. Unlike newer versions of Android, I don't have the option to select or see what audio codec is being used in developer options (if enabled).
Downloaded wireshark (it's a free program) and made a bluetooth hci log on the Note 4 to see. Turns out it's using SBC at 328kbs (44.1khz) and further digging to check the SBC bitpool showed a bitpool size of 53 which confirms this.
Interestingly enough, the BT20 did report it had APT-X capability in the log. I don't currently have a way to try and force it to use it, to see if it will actually work.
@Slater I was able to verify aac option using android and logging the bt.
What? These don't have earhooks. They're just downright bulky and can hardly be considered "IEMs".Fatal flaw though, earhooks.
Sennheiser, Apple and new beats have this feature. Lots of others as well. Should be easy to find a pair. I’ve found it doesn’t work very well on most.Does anyone happen to know any similar TWS that has transparent hearing/hearthrough feature. I been addicted ordering TWS earphones but realize that I don't want to disrespect my coworkers by having both earphones in and have them repeat what they say lol. I know I could just use one ear piece for mono but just seeing the options
Jabra 65t also has this. And you can config transparency level via the appYeah I have the Sennheiser TWS and it's really sensitive. Too bad I can't adjust the settings but I'm searching for smaller forms and trying to be more discreet about it without looking like Frankenstein lol . I know I can't find the perfect product but my go-to at the moments are Mavin Air-X and the anbes 359
