Mar 28, 2024 at 2:03 PM Post #61,367 of 70,017
TW2 and adapter came. Paired with Prestige LTD. Can't complain about sound quality. You lose some of both extensions (bass and treble), less dynamics, stage feels shallower in terms of depth but overall I'd be absolutely fine on the move. TW2 are not 'transparent' to my ears.
The only problem is the fit which, due to adaptors and profiled stems/cable (?), makes all a bit uncomfortable after a short while. It puts pressure on the anti tragus area.
I'll try with different IEM's but, with regrets, I'm not entirely convinced..
What mmcx to two-pin adapters are those?
Mar 28, 2024 at 2:20 PM Post #61,369 of 70,017
I've tried different settings including Aonic 215. The change in sound (wired vs wireless) is negligible in real life use (wireless). I do not mind it. I won't be critically listening on the move :wink: The change is there though but who cares. My main gripe is just the fit.
Remember kids: disable Dolby Atmos before judging TWS's!
This bloody "feature" was enabled.. it makes TW2 sound worse
Mar 28, 2024 at 2:22 PM Post #61,370 of 70,017
Any impressions on the Cambridge from theft coast?
They’re nice. Messing with them now. They fit perfectly. Case is like the Beoplay EX but plastic. ANC is better than I thought it would be. More soon and pics!
Mar 28, 2024 at 2:33 PM Post #61,372 of 70,017
Just got the suckers in
Mar 28, 2024 at 2:50 PM Post #61,373 of 70,017
Mar 28, 2024 at 3:13 PM Post #61,375 of 70,017
Just ordered these adaptors. TYVM to our Supreme Leader 'erockg'...
Between these and this one, hopefully will get a good fit with the C~Encores.
I've stupidly spent way too much money experimenting only to rinse and repeat every few months. It's a blessing and moreso -- a curse.
Mar 28, 2024 at 3:29 PM Post #61,376 of 70,017
Few pics comparing the M100 vs others.
Mar 28, 2024 at 4:56 PM Post #61,377 of 70,017
Pretty pleased with the MM100 so far. Sound wise I'm enjoying them without too much EQ tweaking.
If I was being picky though, I can't seem to get a solid/secure fit in my right ear (the left is fine) and not a fan of the touch and hold volume control which isn't easy to be accurate with. Minor nit picking I guess though.
Mar 28, 2024 at 5:00 PM Post #61,378 of 70,017
M100's not shipping to Aus which is pretty devo.
Wanted the special little hikerdelic version
Mar 28, 2024 at 5:22 PM Post #61,379 of 70,017
BTW do you still have your Gemini II??. Are you using the stock tips. Found that the profile of the unit has changed the included tips do not seal as well as the Gemini I, but then I found that the tips were also a larger on Gemini I.
