Jul 12, 2022 at 8:58 AM Post #46,606 of 70,652
Two more findings for amazon / prime day ... check your other wishlist items, I just noticed the Soundcore Life / Dot A3i getting a 20% off voucher, unrelated to prime day ...
Also, saw only on the front page after some scrolling: A lot of items in Amazon Warehouse get extra 20% off .. i.e. found Jabra Elite 7 Pro for below 100€ that way (did not buy though, I am being a good boy :D ) ...
Jul 12, 2022 at 10:23 AM Post #46,607 of 70,652
Jul 12, 2022 at 11:43 AM Post #46,609 of 70,652
Jul 12, 2022 at 12:22 PM Post #46,610 of 70,652
Jul 12, 2022 at 1:00 PM Post #46,612 of 70,652
First impressions while unboxing the Beyerdynamic Free Byrd:
  • Completely environmentally friendly cardboard and paper packaging.
  • The buds are as expected pretty big.
  • The case is somewhat comparable in size to the EX’s case and feels relatively premium, although the lid has a little play from left to right on mine when closed.
  • They are a bit awkward to insert at first but once they’re in the sit fairly stable and comfortable (at least for now) – many tips to choose from as well (5 silicon pairs + 3 foam ones).
  • They get very loud, even louder than the EX and the MTW3 for me.
  • They seem V-shaped to me on first listen, with a very strong bass and elevated highs but somewhat subdued in the mids. Haven’t played much with them yet, though. Have to try the sound personalization a bit more, too. So far I’ve only used an old profile that was still in the app.
  • The touch controls work really well so far. I like the bigger touch surface on “big” buds, just like the MTW3 compared to the small round glass surface on the EX. There is a little feedback on each tap, almost feels haptic.
  • I get a very good seal with the included tips, have to use XL, though, which is a first :D
  • ANC seems a bit better than on the EX but not as good as on the MTW3 so far. It is also just either "on" or "off" - nothing "adaptive" here.
  • Battery percentages are shown/updated in 5% steps. The case's battery is not shown in the app, though.
  • There is no Equalizer but there are EQ presets: "Original", "Bass Boost", "Warm", "Smooth treble", V-Shape, "Speech", "Brilliance".
  • There is a "Low Latency Mode" in the app as well.
  • How to use each touch gesture is also shown in the app.
  • Single bud mode and auto pause work very well.
  • Battery life already seems pretty amazing, as expected.
  • Had one call with them so far, no problems at all and the other side said I was very loud and clear.
Early days of course. Will now test more and update here.
Jul 12, 2022 at 1:33 PM Post #46,613 of 70,652
The clarity on the IE600 is incredible. I'm also amazed at how wide the soundstage is. Might try them on my Fostex TM2C and see how fit etc. compares. Been reading a ton about the IE600 and every kind thing I'm reading is correct.
are they readily available in the US now, or did you get them shipped from overseas?
**edit**
NM, I see them all over via US online retailers. I've been completely disengaged from reality dealing with startup woes and a sliding economy. :(
Jul 12, 2022 at 2:42 PM Post #46,614 of 70,652
Hi folks, have anyone compared Sony Linkbuds S with Technics AZ60 in terms of sound quality? I've been using the latter for 6 months and mostly satisfied, but seeing a couple of positive opinions on Sony's here, I'm wondered if it's worth trying them
I had the Linkbuds S briefly, I also own the AZ60 ... while there is a lot of good on the LiBu S (?), the Technics still sound better IMHO, hence I returned the Sonys
Jul 12, 2022 at 2:49 PM Post #46,615 of 70,652
**edit**
NM, I see them all over via US online retailers. I've been completely disengaged from reality dealing with startup woes and a sliding economy. :frowning2:
Grabbed them from Audio46 in NYC. They seem to sell out most places as soon as they are in stock. So far so good.
Jul 12, 2022 at 3:06 PM Post #46,616 of 70,652
I have listened to both models on separate occasions, but not through a direct comparison. Sound quality is great on both buds. I ended up purchasing the Linkbuds S after listening to them in-store, and was quite surprised at how balanced and detailed they are, with an impressive soundstage given their size. Off of memory, I don't recall the AZ60 sounding any worse, but I very much enjoyed the treble that the Linkbuds S offers, with plenty of clarity and 'bite' but not emphasized in a way that can become fatiguing. This is all based on EQ settings 'OFF", with LDAC and AAC codecs used (minimal audible differences between the two). For reference, I also own the Lypertek Z7 and Sennheiser CX Plus. In terms of sound, I prefer the Linkbuds S over the Sennheiser, but would put them on par with the Lypertek - a triple hybrid driver TWS iem that is highly regarded for it's sonic clarity and control.
It doesn't hurt to give the Linkbuds S a shot! They also come with Bluetooth LE ready for when it is launched sometime in the near future, if that tickles your fancy.
Hope this helps
Jul 12, 2022 at 3:47 PM Post #46,617 of 70,652
Thanks. I hope you will consider reporting back after a bit more time listening, especially if you have any other buds to compare them to.
Jul 12, 2022 at 3:48 PM Post #46,618 of 70,652
Hi folks, have anyone compared Sony Linkbuds S with Technics AZ60 in terms of sound quality? I've been using the latter for 6 months and mostly satisfied, but seeing a couple of positive opinions on Sony's here, I'm wondered if it's worth trying them.
I own both products and currently prefer the Linkbuds S over the AZ60.
AZ60
Pros:
  • good multipoint connectivity
  • decent battery life
  • excellent fit kit with lots of tip sizes
  • premium build quality and materials
  • nice small case
  • decent large sound stage
Cons
  • a bit on the big side.
  • a bit uncomfortable at times.
  • bass has a bit to much bloom for my liking
  • midrange is slightly to warm for me
  • treble lacks a bit of detail and sparkle
  • occasional complaints from people when using these for phone calls in noisy places.
Linkbuds S
Pros
  • very small in ear making them the most comfortable TWS I have bought, so far no hot spots from them at all
  • quality of life features work well if you take the time to train and use them.
  • app offers good insight into usage.
  • nice small case
  • Sony hybrid tips are always super comfy
  • charging from case is pretty fast
  • extremely balanced signature that is not boring by being flat or too analytical. to my ears it has none of the sonic cons I listed for the AZ60. This is Sony's best bluetooth based headphone I have owned in regards to signature and balance in the past 4 years or more.
  • mic quality on these are better than any other TWS I have owned. My mother is a big gauge for the microphone if she complains about not being to hear me because of to much background noise I know I have an issue and so far she has never complained with these and if I ask her how I sound she mentions I sound good even if there is wind or a far amount of back ground noise.
Cons
  • battery life is definitely shorter than AZ60 but features like auto stop sensors, setting up ANC to not run for certain activities or location help improve this issue.
  • case battery life is shorter than AZ60
  • sound stage is slightly smaller than AZ60
So, if you struggle with the AZ60 being uncomfortable or have any issues with its signature like I have listed, or find the microphone not quite good enough, the Linkbuds S may be a good alternative. If you need multipoint pairing, a bit more battery life, or look at my sonic cons for the AZ60 and think to yourself "he is so wrong!", then the Linkbuds S would not be a good option. In regards to 3D presentation I think they are very equal.
Jul 12, 2022 at 4:10 PM Post #46,619 of 70,652
A few deals on Amazon UK prime day (linkbuds s £130, B&O EQ £219, Shure TW2 with SE215 £148 or £115 for just adapters, 1MORE comfobuds mini £65, Nothing ear(1) £60).
Best one is Samsung galaxy buds pro for £99. In addition, you can claim £75 cashback from Samsung (if purchased today) in return for any old broken earphones or headphones (wire or wireless, any brand), making them just £24.
More than happy with the Grells I'm currently using but hard to say no at that price, even if I just try them and sell them.
Some great deals. The Galaxy Buds Pro 2 is coming next month. Maybe thats why the huge discount.
Jul 12, 2022 at 5:04 PM Post #46,620 of 70,652
Firmware and app update for the 1MORE Evo.
10 band custom EQ now available
And also they now remember your ANC settings the next time you use the earbuds. It took them long enough to figure that out! My question now is whether transparency mode works with just one earbud.
A bit disappointed by Prime Deals as they're not offering free trial membership in Canada but rather 1$ for a 1-week trial. 1More EVO is 171$ CAD and Liberty 3 Pro is 140$!
