50 is the magic number but would be nice if they could have gotten 2 full charges extra with the case instead of 1.5.
Size comparison pic...
Big but not the biggest. Nuarl size I would say but they are packing a 9mm, two air chambers for the driver and a big battery so to be expected. Easier fit and more comfy than the Nuarl N6 form factor.
Went out to the store. Only a little ANC and it is solid but still out for review. Actually the warmth and the good weight of them was good against external noise and I noticed that made them stand out in the busy store. Ambient again very quiet going on with no click or activation noise outside of the lady. Though the quick transparency on the right bud has no announcement so I could double check easy enough. Again very natural ambient up there with the best/most transparent I have heard.
Tried Spiral Dots and they fit fine in the case. Liked the stock tips SQ a little better. Maybe the ones I used on the CKR70TW I like a smidge better than stock but just a tiny bit. Much better tips than the last gen which were not that close.
The lady still gets confused. If you play or pause on the device she remembers what was last with the earphones so you get her to say pause when you play.
These take EQ well. They do like a cooler source of course. Normal(no EQ) on my Cowon is never used since it is cool and a bit unexciting but these warm that up and I like it. Actually like the quality and tone of the treble on these. Delicious bass on one side but quality treble and good mids These are tuned similar to many TWS and the CKR70 I had that they are low end focused and you might want to add to the higher registers. Just better than things like the CKR70TW and the Victor. They have quality through the range and they can be pushed where you want. bass is the star but they can be evened out. Still need to see how the run in changes the bass if it does.
