Ceeluh7
Ha.... Nice....too funny man.Ya, only because I.. also have a set of Devialet Gemini's on the way..
Typically the bud connected to your phone uses more battery since the other bud is piggybacking off the connected bud.Do you have any issue with right bud drains more battery than the left one does? My right buds always drain 2-8% more than left bud. From 100% - 40%, it is 1-2% difference. But when the battery life reaches below 30, right bud is always 6-8% less than left bud. I fully charged first time before using it but right bud died without telling me anything.
I never had TWS before. EQ is my first one so I am confused. TWS is always on. So I guess the right bud is the one which connects to my IP8+. Just feel uncomfortable about thisTypically the bud connected to your phone uses more battery since the other bud is piggybacking off the connected bud.
Are you using TWS mode? Not all phones support TWS mode, but that links both buds to the phone at the same time. Not sure if that would use less battery though since both buds would be connected.
That's really useful, thanks for the quick response!
Really like the default tuning, but it doesn't work for everything, so seems like a no-brainer to return them and get the Aurora Blue.
Agree about the Sennheiser eq, it's not great. Wasn't a fan of the 'neutral' pre-set initially, so bumped up the treble and lowered the bass a bit, but eventually found that too shrill so moved the sliders back a little, but that made it nearly indistinguishable from the neutral setting, so gave up and left it at neutral most of the time. Getting the right ear tips made a bigger difference. Stock tips didn't fit well, and foam reduced the clarity and felt uncomfortable (although helped remove sibilance), but Spinfit CP360s are working better. Comfobuds Pro are far easier to get along with though.
Agree, I much more gravitate to tws just for the form factor, I do have a bunch of iems and when in the mood the Utws3 serve a good purpose. BTW utws5 does look nice... Still haven't gone to market I don't think?
Yeah, the TWS cases aren't portable at all which is a shame. I've kind of turned away from adapting TWS headphones and going towards a normal BT cable for the headphones.
Ordered the Gemini, pretty jacked about that and should be here tomorrow... Thank you for all the thoughts.
Hopefully these will be my endgame set..........
I almost said that with a straight face...
No, just Zoom. Zoom. And more ZoomWhen you're on a Zoom call using the Jabra, do you also have Skype for Business or Microsoft Teams running in the background?
I recall my Jabra Evolve 2 65 behaving this way when my organization was transitioning from Skype to MS Teams. It was muting it by itself.No, just Zoom. Zoom. And more Zoom
Endgame? Hahaha I don't think so...only when you quit the hobby and delete your account here in Head-fi will you really start to mean it
That is actually TWS+ (Plus) and the phones chipset needs to support it or the buds will run as Master+Slave (some buds can still swap over to balance out the battery life) it has been replaced by TWS Mirroring where the phones chipset support does not matter.Typically the bud connected to your phone uses more battery since the other bud is piggybacking off the connected bud.
Speaking of Soundpeats, for the H2 they went stem...Forgot to post this, but SoundPeats now have a new working App out for Android, worked for my H1 Prems (faulty), did not work for Sonics (faulty), T2's (faulty) or Sonic Pro's.
https://play.google.com/store/apps/details?id=com.thirtydays.headset&hl=en_GB&gl=US
Wow man... My Soundpeats H1 now have an app... Thank you for posting. I just tried and my H1 successfully are logged into the app.Forgot to post this, but SoundPeats now have a new working App out for Android, worked for my H1 Prems (faulty), did not work for Sonics (faulty), T2's (faulty) or Sonic Pro's.
