Dregur
- Dec 2, 2004
WF-1000xm3.
I actually had the xm3 until Tuesday, but I ran out of time & had to return them. I was messing with the Touch connection issue then charging issue that I sadly didn't get a chance to do A/B test. I finally think I have the Touch figured out - jiggle it a bit until the red light comes on then you are good to go.
From my memory, I'm pretty sure the Touch have slightly better sound in a smaller lighter package. Bass is slightly on the strong side much like the Sony, mids need to be EQ'd a bit to raise a bit, highs are not as smooth as the Sony, soundstage might be slightly better on the Touch, I feel Touch are bit better in sound quality, Touch are smaller+lighter+ipx4 water-resistant, Sony has better app/case but it's close enough, Touch also have aptx. Overall I think Touch are better because smaller package, better bang for the buck, more comfortable and I think they sound bit better. I am kind of mad I didn't have the time to do A/B test. I actually had time but didn't use it properly.
If CA can get the connection issue fixed, I think these are great earbuds. They sound pretty much on par with the cx400bt, which have same drivers as the MTW2. I think cx400 had more neutral sound that was great out of the box. Touch needed some EQ, doesn't quite sound as natural and cx400bt was better with the highs. Cx400bt was barebones with no iptx water-resistance, no transparency mode and not comfortable. Touch has advantage in all 3 things.
I don't have a ton of time to do an A/B, but I dislike the Sony's sound in general. Compared to the MT's, the bass is boomy, and the resolution and imaging is incredibly congested. The ANC is pretty good (not as good as any of my ANC over the ears of course), but I have been trying to find a replacement TWS with similar to better ANC because I don't like the sound. The fit/comfort is okay for me, but the MT's definitely win. The case feels better than the MT's but it is quite a bit larger, but does come with NFC, so initial pairing quite a bit easier.
