What tips are you using?I think they're all around better than the TWS. The bass is a basshead's dream for wireless. Tight and sharp, even without the personal setup turned on. I think the Nuraloop is almost better than the Nuraphones in sound quality. It is in portability. I would suggest a tip roll for the Nuraloop. Good tips can be found that fit, unlike the Nuraphones.
Going fully Wireless IEMs. Too soon? Or are we there yet?
- Thread starter webreaper
clerkpalmer
- Dec 16, 2015
Thanks. That's high praise. I wish they were about 50 bucks cheaper.I think they're all around better than the TWS. The bass is a basshead's dream for wireless. Tight and sharp, even without the personal setup turned on. I think the Nuraloop is almost better than the Nuraphones in sound quality. It is in portability. I would suggest a tip roll for the Nuraloop. Good tips can be found that fit, unlike the Nuraphones.
go0gle
- Jul 31, 2010
Finally got spinfit 360 on my lp2, very comfortable and sounding a bit more open overall. Very niiiceee
Mixmasterjw
What tws is best for rock/metal music?
erockg
Huge Maiden fan and more. I'm rocking the Sennheiser MTW2 and I love them.What tws is best for rock/metal music?
The L2Ps are great for metal. I was rocking some Dio today in honor of Ronnie, and it sounded awesome.What tws is best for rock/metal music?
I own the 6 listed in my signature. Fortunately, i don't have to fight that battle haha. I'm sure if i were married, i'd be fielding questions about my audio purchases Good thing i don't have that problem, because this week i bought 2 new over ear bt headphones.Out of curiosity, how many different pairs of TWS do each of you own? And if the number is high, how do you explain that to your wife?
Nailzs
- Jul 8, 2007
Tips I dug up from past earphones. I did find foam tips that were with my Mee Pinnacle P1 earphones that fit but didn't seem to let the Nuraloop function correctly. I need to experiment more with the foam tips.What tips are you using?
Dude, thanks for the awesome advice! I'm definitely going to pick up the MTW2
Sounds like you love JH tooI listen to my Lola's ALL THE TIME... I'm using the 2.5mm balanced cable, going into my HiBy R6 Pro, or into the balanced on my iFi xDSD. My next big purchase will be some custom IEM's. I'd originally thought of getting the top of the line JH (Layla?) but I might branch out - there are so many other options out there.
I should prob just sell my JH bluetooth cable. I love the form factor but I just can't get into the heavy bass. By the way, thanks for the "bass warning" on the Jabra 75's - I was just listening to my 65's today and pondering whether I should grab the 75's. Sounds like they wouldn't be a good fit for mr.
Anyway, thanks again. I switched to some foam tips on the XM3's today and they sound maybe a little bit better but it really sounds like the MTW2 is gonna be what I'm looking for
[/QUOTE I had to eq, like i did with the 1st gen mtw, but i like them a lot over all. Imo, they'll be a great complement to your n6p
tendou
- Mar 5, 2012
Between qcy t5, qcy t2c/qs, haylou gt1 and tronsmart spunky beats which one do you guys prefer?
And can you compare the charging case for them with the haylou gt1?
https://www.facebook.com/oBravoAudioES/posts/782853322119674
Seems Obravo is coming up with a planar TWS!
This is very very ambitious I gotta say, considering my planar IEMs need a lot of juice/amping.
Spidermanxd
Member of the Trade: IEM Reseller
If that the case, you lucky to get 3 hours per charge on thesehttps://www.facebook.com/oBravoAudioES/posts/782853322119674
i paired my SFR MT100 (which uses planar driver and a knowles BA driver) with my BT20S with great result. haven't test them for full battery length though
DynamicEars
- Jan 5, 2019
You will want the Haylou GT1 PLUS not pro not vanilla not anything else.
Better than QCYs i have t1c and T5 for me because more balance, less shouty with great details and nice bass texture.
But the haylou volume level is not loud enough for me at 90%, and 100% too distorded, sounded like the drivers are working too hard.
And spunky beats i well regarded and bartig/scarbir also recommended them but this is from his blog 2 months ago on haylou GT1 plus review
And now im curious about KZ Z1 because some reviewers who love the GT1 Plus said the Z1 have better sound quality (with a lot of cons lile 2.5 batt life, AAC only no APTX, no mentioned of IP rating etc)
clerkpalmer
- Dec 16, 2015
Dont know much about this company but its nice to see some innovation. Anyone familiar with they stuff? Any details on these?https://www.facebook.com/oBravoAudioES/posts/782853322119674
Total: 164 (members: 4, guests: 160)
