From the "ag" branch of Final, the TWS04($146 current converted price)...
■ High sound quality specifications supervised by the audio brand final The sound
quality is fully supervised by the Japanese audio brand final. Suppresses the sound quality that makes Bluetooth tired, which is easy to hear, and combines clear, transparent vocals with sufficient bass.
■ aptX compatible
with continuous and high-quality sound In addition to SBC and AAC, it also supports aptX, which is a continuous and high-quality codec. It supports a wide range of iPhone and Android models, and pairing is easy.
■ Compatible with both waterproof performance and sound quality With the
newly developed waterproof mechanism, high waterproof performance is achieved without impairing the sound quality.
■ Up to 180 hours of music playback
Up to 9 hours of music playback on a single charge. Ultra long battery specification that can play for up to 180 hours using the included charging case.
■ The
charging case equipped with a large-capacity battery of 2600mAh
with a mobile battery function can also be used as a mobile battery.
■ High waterproof specifications IPX7 With
IPX7 waterproof specifications, it can be used safely even in the rain or in sports.
■ Charging case with leather grain finish The charging case with leather grain finish has a nice
texture and is easy to touch.
■ Supreme comfort The
new earpiece designed for perfect wireless earphones, final "TYPE E exclusive wireless specification" is included in 5 sizes.
■ If lost, you can purchase one ear
If you accidentally lose one ear, you can purchase only one ear on the ag official website.
Specifications:
Model number: AG-TWS04K
Communication method: Bluetooth 5.0
Playback frequency band: 20Hz 20KHz
Compatible codec: SBC, AAC, Qualcomm aptX audio
Compatible profile: A2DP, AVRCP, HSP, HFP
Continuous music playback time: Up to 9 hours (up to 180 hours including case) )
Charging time: Earphone body: 2 hours / case: 4 hours
Battery capacity: Earphone one ear 45mAh / case 2600mAh
Accessories: Charging case, earpiece (final TYPE E complete wireless specification) 5 sizes, USB type C charging cable
