Luke Skywalker
Ya it’s a little steep. If they had LDAC then maybe ...That's too much money imo ..
Hi everyone
I have T1X and like them with comply tips
now looking at either LP2 pros or Mifo 07
I like a fun sound - I listen to mostly country and old rock
I don’t need sound isolation or cancellation
which of there 2 would give best sound quality?
I could spend up to $200
any other suggestions appreciated
Thanks
Hi everyone
I like a fun agressive sound (not analytical) - I listen to mostly country and old rock
Thanks
Anyone else using the Echobuds here these days ?
I think this was mentioned at one point but when I have "ANR On" there is a weird "plugged ear" feeling when I turn the volume down from 11 to 10 (I counted all the Vol+ presses from mute). It's not there with ANR Off. This must have come with a recent FW upgrade because it definitely was not there initially.
Check out my most recent comment on the WF-1000xm3, the fit is a disaster
@asak - Thanks for pitching in. MIn my case it's clearly volume related, with the ANR ON going from level 11 to level 10 changes the sound completely in the right eat. At 11 it's fine at 10 the right ear is "plugged". I see I'm on 306714878 so way behind you ! I'll try to update them, the process is such a pain with things supposedly happening "in the background". Couldn't do like everyone else and have a menu dedicated to that...
and even if you do happen to get a good fit, as I did, forget about moving around. The Sony's break seal easily and have this bizarre "flopping" thing going on walking briskly. And I'm not talking about runner's thump.
Wow I find mifo07 is very comfortable and I can even use it while sleeping. I am using a modded foam tips on them and it makes a big difference as using a silicone tips creates a pressure on my ears.I want to love my Mifo o7 but find them uncomfortable and they slip out of my ears. Can anyone recommend me some eartips that fit in the case? I like the AZLA but impossible to get them at the moment, in AU at least.
