Ah ok I thought you were referring to the behind the ear adapter. Love my V80s, I did have a hard time finding the right tip though, I settled on some L Anjirui foams.
Yes I was. Ordered the behind the ear adapter to go with v80s. Thanks for the tip on the tips. I have the spn700 and love them. The 1000s should be similar if not identical
Great choice
My 1000x perform (largely) flawlessly. I think the problems affected the early production runs on the original firmware.
ALSO as someone mentioned earlier it would be nice to find a wired earphone that has the same signature. None of the Sony earphones (admittedly not high end) hold a candle to these.
They outright sound excellent by any standards. So smooth warm yet detailed. Totally unfatiguing and satisfying.
The sepeperation and imaging is THE stand out characteristic, among the best I've heard. Hard to believe they can seriously be beaten by any other totally wireless. At least in terms of pure sound
Look out for amazon warehouse deals. I got mine 'used like new" actually brand new and sealed for just under £90! One of the biggest bargains and the best audio related purchase I've made.
Has anyone had any experience or recomendations for a good BT cable for a 0.78 2 pin (non-bluetooth) IEM?
I had considered something like the Earstudio ES100, but I thought a more compact BT cable/adaptor might be better than having to deal with being stuck with, and having to deal with the long cable that comes with the IEM.
Thanks well in my research for the adequate earbuds
I came across the jabra elite 65t active the 1000x for a very good price
And due to my s... experience i don't know what should i do
i have to say i would feel a little bit dumb if i took the 1000x and like in one month there will be a new ones
it s the same with the IconX 2018 which seems very good
yes sure thing
but i would like to get the best for the price as anyone i guess
and i have to say
I am still a student so +100 euro for earbuds u think about it twice but we live only once so meh haha
