Richardhoos
Quick question Baten (or others!): if using the above set up, am I essentially not using the “balanced” properties of the cable? In other words, probably not getting the most out of the cable?
The Gilmore Lite is a single ended amp, using the adapter will make the cable behave like a single ended cable. If you want to use balanced you need a balanced amp.Quick question Baten (or others!): if using the above set up, am I essentially not using the “balanced” properties of the cable? In other words, probably not getting the most out of the cable?
Quick friendly check-in for @justin w. to see if any progress has been made with the bespoke power supply?
We keep asking about the upgraded power supply for the Gilmore Lite MK2 and HeadAmp is not answering. Originally I seem to remember the power supply was supposed to be available in 2018 and then the first part of 2019. I know HeadAmp is a small company and I love and respect their products, but it seems like finishing this power supply shouldn't be quite this prolonged. There is most likely a Chinese linear power supply that could be adapted to work so that might be something to check out.
Stay updated on HeadAmp at their sponsor profile on Head-Fi.
It is something I have been working on. This is just the current idea which includes the Golden Reference Low Voltage power supplies and as many as 3 output ports. Also, it will have to be a little bit larger than the GLMK2, maybe an inch or two deeper.
Measurements are not the end-all. Though I do find them important on the DAC side. I assume the GLMK2 will not measure stellar because when I connect a Modi Multibit to the 887 the sound is... not good. The shortcomings (my preferences) are immediate. The Gilmore Lite MKii sounds great with it though, lending to my belief it is more forgiving.That look cool, any plans on sending a GL mk2 / GSX to Amir to have it measured? Love to see how it compares to the other amps on his list
When fed with the D70 the Gilmore picks up more detail however can't get close to the 887 (which sounds great with the D70 as well). HOWEVER... when it comes to music I always prefer the MKii. It sounds more enveloping, the bass is more natural as the THX's bass is so accurate and focused it loses out in engagement. The Mk2 has great extension and good detail while being musical, warm and just a blast to listen to. The vocals sound fuller as well. If I need a scalpel I'll plug my cans into the 887, but I want to enjoy the music so I prefer Justin's product. I only use the 887 for gaming now and it serves its purpose very well there.
