The fake one will work. Not sure about the JAYS actually. I picked mine up from a local store.
[FYI] Various IEM's tips pictorial comparison (updated Sept 29th, 2011)
- Thread starter ClieOS
kanuka
- Dec 12, 2010
silly question. are the fake hybrid 'legal ' ?
I don't think Sony ever applied a patent on their hybrid eartips, so there isn't any question regarding legality.
kanuka
- Dec 12, 2010
thanks
do they fit the dba-02/B2 too?
kanuka
- Dec 12, 2010
ok then guess i'll order the 9 pairs for $7
kanuka
- Dec 12, 2010
it's been more than a week im using the pl50 with the M silicone tips.
i donno why but i get the feeling the isolation got worse, quite worse. what should be the reason?
did the tips got softer and just dont block the noise? or something else? and how can i fix it?
Well, silicone eartips do absorb skill oil / earwax and get softer with time (a.k.a. break-in). No sure if that's your case though. Maybe you didn't quite get the best fit?
kanuka
- Dec 12, 2010
from all the tips , those are the only that really fit my ears, isolate and dont pop out. i think its the same fit i got at the beginning . truth is , that at first i got more pressure in my ears, and now dont even feel the tips. but the isolation the first days was much better , even in quite noisy places
i doubt they already broke-in with only 1+ week of use , about 2-3 hours a day. and doubt even more that my ears got different
kanuka
- Dec 12, 2010
hi is there any difference between the shure and ety tri-flanges?
and another question
they sell on Ebay some tri-flanges, same seller that sells the sony hybrid clones,
http://cgi.ebay.com/earbud-Replacements-Noise-Isolation-Tips-Sm-MD-LG-/160463395521?pt=Other_MP3_Player_Accessories&hash=item255c5d1ac1 how are those compared to the originals?
Ety tri-flange tends to be just a little harder, but overall the difference is very small and you probably can't tell it if you are not compareing them side by side.
Those are for IEM will big nozzle. Not those from Shure / Ety / Westone.
kanuka
- Dec 12, 2010
and for the meelec a151 and others with 4mm nozzle?
Then you should get the one that said it is compatible with Ety, Westone or Shure.
Anyone have a recommendation for a good bi-flange that will work with my Turbine Coppers(and where to get them)? For reference, Sony Hybrid mediums and smalls(but not the extra smalls) work best for me. I want as much isolation as I can get, but have issues keeping a seal with the various Super Tips, and tri-flanges(both larger and smaller ones) sort of "bottom out" on my ears.
First post updated with Comply, Shure and JAYS foam comparison.
MEElec bi-flange should fit, and they are of good quality.
