Lohb
Grzegorz stepped up and made it happen! His LCD2 v1 Wave Guides work great.
The Wave Guides were 3D printed by Shapeways.com for $29.00 for a set of 4.
I made measurements of LCD2 v1 Stock, with Rear Side Wave Guides, and with Rear Side + Ear Side Wave Guides.
Listening impressions and measurements will follow in a couple of days.
The Rear Side Wave Guides were a perfect Drop-In and friction mounted with stock thick felt over the wave guides, stock foam over felt, and metal grilles over foam.
The Ear Side Wave Guides had to be rotated 180 degrees, corners snipped to fit, and secured with hot glue.
Next up...Wave Guides for Fostex T50RP by none other than Grzegorz, "The G-Man."
4 Wave Guides by Grzegorz
LCD2 v1 Rear Side with stock thick felt, foam, and grille removed
Rear Side Wave Guide drops in and fits perfectly by friction mounting
Stock thick felt over Wave Guide on the Rear Side
LCD2 v1 with stock foam over stock thick felt over rear
side Wave Guide
Ear Side of LCD2 v1 with pad removed
Inverted Wave Guide with corners snipped to fit.
Secured in place with a bead of hot glue around the edges.
The pad goes over this mounted with double-sided tape.
No loss in the low-end ? Then I guess the Fazor driver upgrade caused this perceived change in the low-end some report on F model Audeze and not due to the Fazors themselves.
2.1's....deep dark chocolate...yummy.
