nick n
- Feb 3, 2011
I recently redid a pal's T50rp memory foam mod to tweak up the bass levels ( still stays tightish ) and added some Sorbothane around the baffle side of the driver.
He had made a small comment that otherwise would have gone unnoticed were I not paying attention. He said the top end was slightly toned back a bit to better levels.
So because mine suck due to peaky drivers I revisited what I did do his and mine at the same time and added twice the amount of Sorbothane 1cm squares to mine to see what effect it would have according to his comments.
It allowed me to remove an entire layer of earside tuning foam ( from ebay seller Wang Yifei = Sennheiser foam tuning discs ) I had installed there, which took it down to just the square insert over the driver and a single disc under the pads.
Of course the added Sorbothane didn't hurt the sound
Pads fit nicer also, and this is off a cooler source ( Colorfly C3 ) to beefy portable amp even so I might be able to remove another full disc, will try that later.
Anyhow pics are more fun than words.
Latest iteration.
Thanks again for the random comment Master W!
this
now also goes with this plus one tuning foam disc under pads, maybe removing that.
An entire extra row of Sorbothane so 12cm squared extra now per side.
Latest iteration.
this
