- Jun 7, 2007
Like i said, i haven't had a problem, and you know what happens with some firmware upgrades and SQ.......just say AK120. And it is like a virgin, once you do it, you can't go back.
UPDATE from Fostex regarding the latest Firmware 1.1.2
Dear Mr. XXXXX,
I am very glad to hear that most problems that you were facing were solved.
The latest V1.1.2 firmware update was issued mainly because we needed to rectify the operation failure with non iOS device which is iPod Classic.
After cycling the power of HP-P1 to which the iPod Classic was connected, the resume function sometimes did not work properly.
We rectified this point.
Of course we rectified minor bugs which were caused by the iOS update.
The volume bar thing is the typical example.
Does anyone have any further information on the three gain settings for the hp_p1?
From their site
+/- 0.3 db (at 32 ohm load)
which i presume is the first setting.
Thanks in advance.
Logically thinking, the maximum is no gain reduction, each step lower reduces gain by 0.3 db, so the lowest would be 0.6 db lower than the maximum setting, that being no attenuation.
ADD: If anybody listened to the HP-PV recently, impressions would be welcome.
HP-V1 had power issues recently, when solved it should go prod soon.
Will the HP-V1 be competitive with the ASP TU-06/TU-05b or WA7?
