Actually, when you put it that way, that does sound kind of creepy, LOLOLOL!
If you listen through the Tidal Windows program and don't have an MQA compatible DAC, the MQA files will be decoded by the Tidal software. The downside is that the maximum sampling rate of the output after decoding is 96kHz. I think most of the Tidal "Masters" are 96 kHz, but if there are any with higher sampling rates, you would only be able to listen to them at 96kHz, as opposed to 192 kHz or whatever.
The standard "HiFi" albums in Tidal are 44 kHz, so the Masters do offer the advantage of 96 kHz without an MQA-compatible DAC. Just make sure that you go into the settings, ensure that the Hugo is selected as the audio output, and that it is running in exclusive mode. On my McIntosh DAC the sampling rate shows as 88 kHz instead of 96 kHz for Masters if exclusive mode is not selected.
Hope this helps!
