Solid pads? I thought open headphones needed the fenestrated pads ???I've been using these since my OG days. Now on my MG.
https://dekoniaudio.com/product/limited-edition-ear-pads-for-focal-stellia-headphones
Focal Clear Mg Review & Measurements
- Thread starter jude
I use the Dekoni fenestrated sheepskin, 1/2 the price and a bit better balanced iMO than stock pads, AND a great match with Elise!Anyone using any aftermarket pads with their MG?
I just received mine this morning and it sounds amazing out of the box. How ever i think to me, it sounds a lot warmer than the OG. At least the mid bass is well controlled and certainly doesn't bleed in to the vocals. I have played it using my MJ2 and it sounded extremely holographic. With my Elise OTL and ken rad vt231 driver tubes, the bass is sublime and well extended. I was wondering if anyone else tried the OG dekoni pads...
Thanks
Soundizer
- Dec 29, 2015
My Focal Clear MG is connected to headphone out of my TV. I only use the Focal Clear MG for Movies TV Shows. I don’t have a DAC or anything else. Only for TV listening every evening from 9pm to 11pm.
Guidostrunk
Yep. They're solid. I definitely prefer the change in sound to the stock. Better imaging, everything has a more solid feel. Greater sense of depth and height in the stage. I can hear reverb trails and nuances much clearer.Solid pads? I thought open headphones needed the fenestrated pads ???
RayMets1
I actually have a pair of the solid Sheepskin on my Eligias, might just have to try them on my MGs to hear how they sound.Yep. They're solid. I definitely prefer the change in sound to the stock. Better imaging, everything has a more solid feel. Greater sense of depth and height in the stage. I can hear reverb trails and nuances much clearer.
rohitbalan
Oh! I guess I ordered the wrong sheepskin pad for my Clear MG. This one isn’t fenestrated
jriems
- May 27, 2006
I'm using them, too, and haven't really noticed much - if any - audible differences between them and the original pads. And it's soooooooo nice not to have to worry about the ugly discoloration the original pads exhibit.I have the Focal Elex pads sold by Drop, they pretty much look and sound the
same as original pads, they are only $60 https://drop.com/buy/focal-pads-for-elex-headphones
dududuckling
Not really the D30 pro does not use the Saber dac which is known to be a little sharp. It uses 4 x CS43198 DAC Chips, which smooths the peaks making music less fatiguing.
iiWi has a good video explaining the Dac.
Thanks! I am still breaking in the MG, 28 into 40 hours. Will definitely check out the Toppings!
RayMets1
I don't, those wooly headbands look atrocious. Has to be done though with Focal headbands sadlyMy MG's New look sporting the Focal Elex black earpads and black wool headband. I like It!
dududuckling
Hey, any link to the headband protector? Thanks in advanceMy MG's New look sporting the Focal Elex black earpads and black wool headband. I like It!
RayMets1
I bought the Brown one and Black one here, they ship from overseas and take a few weeks, but fit perfectly.Hey, any link to the headband protector? Thanks in advance
https://www.ebay.com/itm/254126561513?var=553469389452
Soundizer
- Dec 29, 2015
It took about 150hours for low end base to clear up on mine.Thanks! I am still breaking in the MG, 28 into 40 hours. Will definitely check out the Toppings!
seppukuslick
Random Lunatic
- Jan 9, 2017
I compared the Clear MG Pro and Utopia, and the Clear MG seemed much... well. Clearer. More dynamically defined and cleaner sounding. The Utopia sounded a bit mellow and almost rough/mushy comparatively... Anyone else experienced this?
