dududuckling
Thanks for the link - The source will be iPhone 11 Max Pro / iPad Pro (sitting on the desk using USB-C output), the DAC/AMP is currently Fiio Q5s TC at high gain / 40% volume / 3.5mm LO.If I'm reading it correctly the Filo specs show slightly more power available when using the balanced output (220mW versus 560mW) so you might hear a difference. However you might also want to try the balanced output using one of these balanced adaptor before you buy a rather expensive cable.
As for using a desktop DAC/amp, that would depend on which DAC/amp and what source you are using. The good thing about the Focal Clear MG is that the better the source, DAC and amp the better the headphones will sound.
I am looking to upgrade in the future to the Fiio M17 or the iFi Audio xDSD or desktop Topping D90/A90 / SMSL / Schiit Gungnir/Ragnarok / Schiit Bifrost/Jotunheim / Matrix Audio/Technics SU-R1000 - too many choices.
