To keep it simple, you're getting a more tactile bass response and a smoother transition from upper mids to the treble, and also better comfort in my case.Interesting, how different do the Fenestrated Sheepskin pads sound vs the MG pads?
Focal Clear Mg Review & Measurements
- Thread starter jude
jonathan c
Plus: they are easy to clean / keep clean and they cost far less than Focal ‘stock’ pads.
Yeah, I forgot those very important points! I did manage to get my hands on some Utopia pads though, it'll be interesting to compare the twos.Plus: they are easy to clean / keep clean and they cost far less than Focal ‘stock’ pads.
caracara08
Just ordered mine! Very excited
Welcome to the club, I hope that you'll enjoy them a lot!Just ordered mine! Very excited
caracara08
Thank you. I’ve tried the Og and thought they were special so I figure the MG will be even… specialer?
The MG is warmer than the OG, so if you're not used to that then it will certainly sound specialer ! Both are excellent headphones in their own ways.Thank you. I’ve tried the Og and thought they were special so I figure the MG will be even… specialer?
caracara08
Do you guys have dac and/or amp suggestions? They seem easy to drive and I was wondering if they scale up at all
caracara08
That is exactly what I’m looking for!!! So excited.The MG is warmer than the OG, so if you're not used to that then it will certainly sound specialer ! Both are excellent headphones in their own ways.
jonathan c
I have two reasonably priced hearty recommendations for hp amplifier for Focal OG / Focal MG: 1) solid state, Flux Lab Acoustics FA-22 ($749); 2) vacuum tube, Schiit Audio Valhalla II ($349). I use both of these with Clear OG. If interested, I have other $$$$$ recommendations…including DACs…Do you guys have dac and/or amp suggestions? They seem easy to drive and I was wondering if they scale up at all
Are the Pros the same thing, just ins a different package?
Guidostrunk
Yep.Are the Pros the same thing, just ins a different package?
What amp is everyone using?
Guidostrunk
Cap modded Mjolnir 2What amp is everyone using?
Massdrop THX 789What amp is everyone using?
