adydula
- Dec 14, 2010
Yes it does.....and it may be, need a schematic or a reply from FOCAL to really understand what they are doing...I havent looked at the impedances of all the Focal cans but I think they are"
Utopia - 80 ohms
Stellia - 35 ohms
Clear MG - 55 ohms
Celestee - 35 ohms
Radiance - 35 ohms
And the sensitivity of them all are over 100db/mw so easy to drive.
Impedance matching = maximum power transfer and least distortion/SWR etc...
I havent see a bunch of Arche reviews or end user comments comparing it with their "presets" against other amps etc...
Good info though + thanks
Alex
Note: https://www.headfonia.com/focal-arche-review/4/
Take a read and see if a $2500 dac/amp is worth it for you. They even compared it with a Schiit Asgard 3 for $199.
This is indeed a crazy hobby!
Utopia - 80 ohms
Stellia - 35 ohms
Clear MG - 55 ohms
Celestee - 35 ohms
Radiance - 35 ohms
Alex
