HiFiRobot
- Apr 1, 2013
Focal Clear pairings pt16:
SMSL VMV D1SE + Alo Audio Rx MK3-B
The best and clearest portable amp I ever heard. And gobs of power.
Alo Audio Rx MK3-B works really well with the Focal Clears. Somehow it reminds me of Bladelius speakers amps, the Class A/B ones not the newer Class D amps. Superclean, dynamic, attack, slam, control. Soundstage is larger on some of the other more colorful amps like ZDT Jr, Liquid Carbon and Cavalli Tube Hybrid. But if you want clean pure power and the Clears to truly rock this is the way to go. The bass boost control works amazingly well, adjust to your liking. Perhaps listening for hours would imply some listening fatigue. Haven’t experienced it yet but Clears are already dynamic and adding Rx MK3-B will make it even more so.
I wish Alo Audio reads this and they re-release the Rx MK3-B as a desktop amp. I believe many would appreciate the sound signature. It is such a great, clear, clean, powerful but still natural sounding alternative to THX AAA amps and such. It is like the clarity from THX AAA but with much added weight to midrange and bass, and a more realistic sound. The synergy with some Hifimans like HE-500 is insane. Probably measures poorly but who cares when it sounds like this. Best pairing is hard to drive stuff as there is some hiss on easy to drive headphones, and way to much power for IEMs.
Tablet source is for show. I am usually sourcing from the computer or one of my streamers.
Focal Clear pairings pt17:
SMSL VMV D1SE + Monolith Liquid Platinum (Reflektor 6N23P-EV)
The comeback of Liquid Platinum.
So I exchanged the stock EH6922 tubes on the Liquid Platinum to some Reflektor 6N23P-EV from Ebay, maybe NOS maybe not, can’t tell.
Anyway the LP is now a different amp with the Clears. The LP with Clears is not sounding flat and boring anymore, and the soundstage is so much better. LP is getting close to the ZDT Jr. The ZDT Jr is slightly more dynamic and hits harder. And has a bit more sparkle in the treble. Liquid Platinum sounds like it has a softer approach, easier on the ear. But the differences between ZDT Jr and Liquid Platinum are now much more subtle and I enjoy both immensely.
Liquid Platinum + Focal Clears went from “meh” to "yummie" and I really cant decide between CTH, Carbon or Liquid Platinum in addition to ZDT Jr. And I got more tubes to cover with the LP.
DACs used mainly SMSL VMV D1se (sweeter), Hegel HD12 (dynamic, harder hitting). Streamed from iFi Zen Stream connected to ethernet, Wifi turned off, USB output, Tidal and Spotify.
Note that the Liquid Platinum is much deeper than the D1SE, but they can be stacked if you add extra feet to the Cavalli amp.
