Grabbed the black one, appreciate the link!If anyone is looking for a good headband cover for their Bathys, look no further. Just got this one in from amazon and they offer colorways that match both the OG colroway Bathys and the Dune: Amazon Link for Bathys Headband Cover
Here's how the light colorway looks on my new Dunes. Even fixed the slight hotspot issue I got on the top of my head without the cover.
Focal Bathys Hi-Fi Bluetooth & ANC Headphones: Early Impressions
- Thread starter jude
- Tags
- focal focal bathys
No problem! It does its job well and actually improves comfort for me. Just may look a little nerdy on flights lol. I cut off the loop and the little branding label on mine and it's more subtle now.Grabbed the black one, appreciate the link!
Damn I should of bought that color, looked much more grey in your other photo.No problem! It does its job well and actually improves comfort for me. Just may look a little nerdy on flights lol. I cut off the loop and the little branding label on mine and it's more subtle now.
This one also fit exactly the same if any of these colors appeal to you. I believe it's just the same cover but a different branding: https://www.amazon.com/dp/B093P8YHNV?ref=ppx_yo2ov_dt_b_product_details&th=1Damn I should of bought that color, looked much more grey in your other photo.
I tried the black one of that and it was good, just liked the color matching with the previous one better with the Dune. (Could have been better adjusted to look nicer in the first photo)
frix
- May 7, 2012
The spice extends life!
Been using the Bathys for a day now and love them. I think my only complaint is I'm not a big fan of the leather pads, was sad to see Dekoni doesn't do anything like the Velour for them.
Hi guys!
I’m loving my Bathys a lot, and have tried using MiMi.
Quick question, does it override the EQ? I currently have my EQ set at dynamic. Should i leave my EQ to flat when i run it with MiMi?
noplsestar
Dekoni is working on new pads for the Bathys.Been using the Bathys for a day now and love them. I think my only complaint is I'm not a big fan of the leather pads, was sad to see Dekoni doesn't do anything like the Velour for them.
Harvey100
Hi, I was wondering about this as well. I use it with my custom eq which is flat apart from a slight mid boost and MiMi set to 30%. I found MiMi set at 50% or higher was too bright for me. I don’t think it overrides the eq as I’ve tested it with overboosted settings and it doesn’t change the added boost when switched on but someone else with more knowledge/experience could confirm? Meanwhile, the Bathys are sounding better and better!Hi guys!
if the rendering is too bright the test must certainly be repeated, the equalizer must be deactivated before starting the adjustment test.
for me at 50% it works perfectly.
Harvey100
Thanks, I’m going to redo the test with your recommendations. Most folk seem to like it around 50%.if the rendering is too bright the test must certainly be repeated, the equalizer must be deactivated before starting the adjustment test.
yes 50% for me is very good
moodsmaster
- May 14, 2014
I have 25% and this is enough for me. Maybe I have to do the test again.
Spoke to Dekoni yesterday at Canjam and they said they’re shooting for a Q1 release for the Bathys pads, thought I’d pass it along. They actually said it’s the #1 most requested headphone as well which bodes well.
gordec
- Aug 14, 2006
How is the Bathys fit compared to the original Utopia? Utopia slips off so easily on my head I could barely move my head.
