Hey, everyone. Earlier today, I was graced by the arrival of the much, much-awaited
Vision Ears EXT. I've spent the past few hours listening intently to them, and here are my thoughts on the in-ear so far:
The first obvious change over the original is the EXT’s elevated low-end, now also powered by a 9.2mm dynamic driver. I recall worries, back when the EXT wasn’t even announced, that augmenting the OG ELYSIUM’s bass would take away from its headlining midrange. Now, I believe those concerns are - to a large degree - untrue. There
is a change in the midrange (and the tonality overall) for sure, but not to its detriment; at least, in my opinion. What the low-end change does is give the midrange a much meatier, earthier support, which, to my ears, translates to power and weight. When a vocalist belts, the force - the
oomph - coming from their diaphragm and chest are amplified. Whereas, the OG had a lighter, wispier, more effortless quality to its vocal presentation.
If I had to give a rough analogy, the OG ELYSIUM is 19-era Adele singing
Chasing Pavements, while the new EXT is 25’s Adele crooning
A Million Years Ago. They both have the same quality and clarity to them, but the EXT delivers it with a richer, more mature timbre. To my relief, that
aged quality doesn’t translate at all to a veil or wooliness. Again, that gorgeously-textured, evocative midrange is still front-and-centre. It’s just a bit earthier and
rooted now. If you’re the type of person to prefer lighter, floatier vocals apparating in the middle of the headspace, you may prefer the OG’s tonality more. But, if you like your vocals with more weight, more impact and more
chutzpah, then the EXT is simply a level above.
Now, when it comes to that woofer’s
own individual merits, I think it’s one of the most memorable bottom-ends I’ve heard since Empire’s Weapon IX drivers. I don’t mean they’re of the same ilk, necessarily. What I mean is that they both have this
character (or
flavour) to them that elevates them above the general
DD sound. It’s what I personally feel tends to lack on FiR or 64’s DD-equipped in-ears, for example. There’s a certain physicality, texture and slam to this one that keeps it from fading into the background and sounding generic after a while. I was certain of this as soon as I heard Lady Blackbird’s
Fix It, and I got chills simply from the low-end coming from the piano’s
sustain pedal. Not even the keys; the
sustain pedal.
That record’s one of the best-engineered, most stirring records I’ve heard in a while, by the way. Give it a go.
That chill also comes from the EXT’s much denser, more solid, more tactile notes, compared to the OG. As I mentioned a couple times in the past, the ELYSIUM can come off a bit wispy or insubstantial when not powered optimally. Instruments don’t always feel weighted or corporeal. There’s a certain
floaty quality I alluded to earlier. The EXT gets rid of the issue completely, to my ears. Instruments on it feel physical and
there, for lack of a better word, and that’s true across both my LPGT and my N6ii Ti. And, with DDs fuelling both the lows and mids, I feel that quality here even exceeds that of a properly-powered OG. Aside from the lows, I believe this is the EXT’s most notable change over its predecessor.
Up top, I personally don’t feel the treble’s rolled-off or lacking at all. The OG comes off airier because of its leaner low-end. But, in terms of raw extension, headroom and micro-detail retrieval, the EXT definitely goes tit-for-tat. I initially gave it a go with the default Sedna tips, and I noticed a mid-treble bump around 7-8kHz. I felt it created a slight gap between it and the upper-mids, causing the latter to sound a bit recessed. But, once I switched to the SpinFit’s, that bump vanished, and I immediately heard a much more linear, even-sounding tonality. I’d say upper-treble energy is equal on both, actually. You get the same amount of openness and air. You just get a bit more mid-treble articulation and bite from the Sedna’s.
So, three-or-so hours in, I have to say that I’m personally as in love with the VE EXT as I was with the OG a few years ago. I feel it perfectly addressed any and all shortcomings it once had, and it even went above-and-beyond in certain areas like the timbre and power of the low-end. That, in particular, made this feel like a true successor to me, rather than patchwork or a minor update; again, like a singer ageing and maturing their technique. However, in that vein, just like fans of singers can have their preferred
eras, there will inevitably be changes that won’t be universally liked. But, hey, that’s what options are for, and I’m glad that both ELYSIUMs - for the time being - are here to stay.
I’ll be running them in further before I get to work on the full review, and I look forward to reading more impressions around these parts as well. Cheers!
