Oh we ain’t goin’ nowhere
Do you have the carrying case for that?
It looks similar to a Batik pattern, a type of cloth either hand-drawn or stamped with patterns in my country and dyed with colors.Every time I see the faceplates, I can help but muse out loud "Louis Vitton is going into summit fi iems?"
Oh no....what happened? Did it fall?
No, the box was totally intact. When I opened the metal case, I noticed a piece of plastic rolling around inside, and then I noticed the broken nozzle. I don’t know what happened or how it broke inside its case. I’m a bit worried now about the long term durability.
Lol... TouchéDo you have the carrying case for that?
Lol... Touché
There actually is a Van Nuys case that would go nicely with the bird’s case...
Lol... Touché
Henceforth the nickname for the DMP will be "Nuclear Football"Is there a nuclear code that you can enter into that DMP? Looks as if you’re carrying POTUS nuclear football
Sorry to hear that man....I’m pretty sure VE will take care of it. And that’s a valid concern on the durability.
Edit: I think IEM manufacturers should move to aluminium shells or some other type of lightweight metal/alloy for universals, similar to what FiR and 64 Audio are using. It definitely provides more durability than acrylic shells.
The one that comes with Traillii? It’s great. Super sturdy and functional. I’m seriously considering buying the big one that holds a few IEM’s and ditching all my other iem cases.How is the Van Nuys case? Is it worth it? I'm thinking of it, but not sure when/context I'd use it for.
Oh right! haha... I don’t have one, unfortunately. I just found that photo online. It looks nice thoughsorry, was referring to DMP Z1 Van Nuys case.
Huh, I actually tolerated Shure KSE’s amp for a long time haha, still consider it “portable” to some extent, although I gave up carrying a WM1Z and an electrostatic amp at the same time in my pocket, felt like a total gangster lolBut there’s a lot of us out here that don’t want a headphone setup or a full out electrostatic IEM setup that requires a separate AMP at all times. So we are looking for the “ultimate” sound that’s just plug and play, as well as portable and comfortable.
