Let’s take an IEM with a really weird tonal balance. How about the tia Fourte? Don’t crucify me, alright?can you explain that ? How and why as the reference you have is based on this brain burn in thing ?
Well, the Fourte’s tuning has lots and lots of peaks and dips and odd holes and plateaus here and there, and often in spots that are critical in an IEM’s sound signature. For example, the pinna compensation: the Fourte has a massive dip right before it that undoubtedly changes how one perceives the sound signature of the Fourte.
Now, if one were to brain burn in the Fourte, this no longer becomes a flaw of it. You just stop realizing that there ever was a flaw, and this makes you unreliable, because the Fourte’s sound signature is inherently colored and a little wonky. This applies doubly so to less extreme examples: you are unable to describe a thin IEM as thin because thin is now the norm for you. You are unable to call an IEM bright because you condition yourself towards a given IEM’s brightness. So on and so forth. It makes one psychologically iron out the characteristics of a transducer, be they good or not, when ideally a reviewer should be able to recognize what they are hearing and be able to articulate it.
