- Aug 18, 2007
Just a question about UDAC2 buying.
I am a new buyer and have never bought UDAC / UDAC2 (for the matter any DAC/HP Amplifier). Have already bought HiFiMan RE0.
Now I have the option to buy UDAC as well as UDAC2. The UDAC2 costs nearly 45% more.
My question is, is it worth paying that much premium for the UDAC2 when I do understand that only the receiver chip is new and that I'll be using my Netbook as a source.
Since I am not finding many UDAC2 reviews online, I am kind of confused.
Any help will be appreciated.
I do not quite understand the technical jargon associated with DACs. However, I do not think I can extrapolate degree of perceived improvement over the original uDAC from such information. Nevertheless, I shall continue to look forward to this thread for incoming impressions. I am happy that the uDAC-2 has retained the form factor/enclosure of the original. I'd be happy to pick one up after a bit more feedback.
There are several improvements in the uDAC-2 over the original uDAC.
(1) Improved USB receiver chip that can decode in full resolution your 24/96 high bit-rate music like what you might buy from www.hdtracks.com or www.linn.com
(2) This new USB receiver chip does a better job decoding the music even at 16/44 CD-quality bit-rates, so the RCA line-out now sounds very much like my more expensive Pico DAC-only (I couldn't tell the difference when switching between the two DACs).
(3) An improved headphone amplifier combined with upgraded DAC which results in a more naturally balanced and transparent sound out of the headphone amp - the sound is now less forward in the mids and not rolled off in the highs. I have heard the prototype uDAC-2 which had upgraded DAC but with the original headphone amp, and the old headphone amp was holding back the performance of the upgraded DAC. However, the upgraded headphone amp now allows one to hear and appreciate the improvements in the upgraded DAC.
(4) An improved volume control, where I can listen to the music several decibels quieter than with the original uDAC before going low enough to get channel imbalance between L and R channels. For people with very sensitive IEM, this allows a wider range of volumes that you can listen to the music.
