IEMusic
E3000 should arrive tomorrow. I’m excited. It will be my first Final Audio IEM (already love the E tips).
You my collect them all :-DCongrats! I’ve owned/own the A, B, D, & F series, but until my recent purchase of the E500, not any of the E series. The E500 is surprisingly great for $21.
Glad you like them, don't forget to burn them in for 200hrs minimumSo, my initial impression of the E3000 is that it’s better than I thought it would be. A lot of mid bass quantity tends to bother me, and comes across as muddy and resonant to me, kind of like a poorly braced full range speaker or a small bluetooth speaker trying to trick you into thinking it has a lot of bass. Looking at the FR curve prior to purchase, I expected a lot of mid bass. It’s still more than I typically like, but I’m amazed at how clean it sounds. It’s not muddy, and doesn’t affect the mids much. The E3000 just has such a pleasing, warm sound that’s still clear. I’m also surprised at how extended the treble sounds. It’s certainly “rolled off”, and doesn’t have a lot of sparkle that people perceive as clarity, but does have a good amount of air/upper treble, though at a low level so it’s subtle. I like that the treble doesn‘t have a steep shelf. The sub bass also sounds great, with more quantity than the FR graph suggests. The mids are so smooth and relaxing, but not veiled at all. There are no deep notches in the curve, and there is a hint of sibilance that can come through, which I actually like because it’s not enough to be bothersome, and all of the frequencies are presented.
I’m glad you guys warned me that these like a LOT of power. You weren’t kidding about minimal volume change for a while, until they suddenly come alive. I have to max out the volume when running it off an iPad, and it’s around 3/4 of the way up on the DFC, for a good listening level. The DFC volume is usually less than half when I’m listening to any of my other IEMs.
Finally, regarding the fit, they are a lot shorter than I thought they would be. I’m used to Etymotics. For some reason, even with my usual size of Final E tips, it’s finicky getting them to seat correctly. Because they‘re short, and the back of the IEM tube is cut off flat, the sharp edges can dig into parts of my ear a bit, so I find myself fidgeting with them a lot. On the other hand, the small size lets if completely fit in my ear, so I can comfortably lay on my side with them in place.
Wow, the more I listen to the E3000, the more they seem like legit bass head IEMs, but w/o a ton of sub bass. The bass is nice and clean. It‘s a fun sound that makes me want to crank them up to unhealthy levels. I can’t imagine what the bass on the E5000 sounds like![]()
That actually brings up a question of mine. Is the E3000 an open-back design? What is the “C” variant of the IEMs, for example E1000C?Use SpinFit tips, as they cover the ports, and really see how the E3000 is a bargain basshead dream.![]()
The e4000 takes bits of both and adds steroids. It's GRAND, BIG and BOLD. Even though it's more expensive, by far... I wouldn't say it's a huge leap up in sound quality. BUT if you blind tested all three you'd definitely pick it out as the more technically efficient. Instruments have this extremely organic quality and the soundstage is much bigger (possibly down to greater body in its entire signature). Bass on the e4000 is for me easily the biggest and the closest you'd get to basshead levels. I couldn't say that of the other two... but that's maybe in direct comparison.
If I was to pick a negative of each. The e2000 could do with a bit more treble extension and sparkle. The e3000 could be ever so slightly more forward in the mids and can be a little dry on certain vocals. The e4000 can be bit too forward and bass which although has accurate decay, can be a bit boomy at times and fatiguing with certain songs. Oh, in regards to power... with the same songs and equipment I listen to the e2000 at 55%, the e3000 at 70% and the e4000 at 85-90%. The e4000 can be a beast to power properly.
EDIT: I meant to say, the little rubber ear hooks they provide are excellent. Easily the best for any thinner cables you want to wear over-ear. I have never had a pair that's both comfy and keeps the cable tucked in when out and about or jogging
