mochill
Don't forget to add all the other iems from final audio design as wellThank you! I might need to get another pair... I really like them...
Just curious, do you think it is possible to buy the A8000 carrying case separately? I transport my IEMs in my backpack along with a lot of other gear daily and it would be great to have a slightly more rigid case than the stock silicone case.
Thank you for loving the A8000 Aluminum and Silicone Hybrid case.Just curious, do you think it is possible to buy the A8000 carrying case separately? I transport my IEMs in my backpack along with a lot of other gear daily and it would be great to have a slightly more rigid case than the stock silicone case.
check here: https://audio46.com/products/final-audio-color-silicon-eartips-for-e-seriesThanks for the eartip info. Anywhere in the USA you can order the clear eartips?
Most acoustic tracks sound phenomenal on the E5000, and yes Nothing Else Matters is a very fulfilling listen. I also enjoy the Synthwave tracks on them, artists like The Midnight, Timecop1983. The genres they get right, they really get them right.You guys that have the E5000, should try some Metallica songs. They sound amazing on it.
For example here are the ones I listen to: One, Sad but true, Nothing else matter and Enter sandman.
The case is great. But I don’t use it, because my a8k with cable won’t fit in it)))Just curious, do you think it is possible to buy the A8000 carrying case separately? I transport my IEMs in my backpack along with a lot of other gear daily and it would be great to have a slightly more rigid case than the stock silicone case.
Out of curiosity, is the cable on the B3 the same as the one on the B1 and A8000? If so, is that the C106 cable?
Also, have any of you had issues with fraying at the MMCX connector because you don't use the ear hooks?
