FiiO X7 Mk II 2GB RAM + 64GB ROM + ESS9028 PRO + Balanced + DSD + BT 4.1 aptX + Dual mSD + Dual Band WiFi + Opt Out
post-14594495
Post #5,026 of 6,073
goldenegg
Tidal has recently removed the crossfade option in the app. Do you still get stuttering?
I use the X7II with Tidal and do not get any stuttering. But before they removed the crossfade options I set it to 1 second. Maybe the App still remember these settings?
I still get stuttering. It renders Tidal useless for me. I thought it was a problem with internal storage, so I moved Tidal to use an SD card. The same problem happens with the SD card.
I am under the impression that Tidal only streams lossless on desktop clients, so for an android device the Hifi vs Premium in this case won't make a difference in SQ.
You can download music in lossless format with Tidal.
post-14595585
Post #5,029 of 6,073
CrocodileDundee
Australia
Australia
what would you suggest for a dap?
Any Android phone with Android 9.0 will support LDAC. Sony phones already support it. for LDAC use, not really a need for an unique DAP.
Reactions: adrsz
post-14595639
Post #5,030 of 6,073
dsrk
You won't be able to maximize the capabilities of the wh1000xm3 because x7ii doesn't support LDAC.
FiiO M9 supports LCAC and it's sound quality is very good for its price.
Reactions: adrsz
post-14595678
Post #5,031 of 6,073
adrsz
sadly im team apple and won't change. anyway thanks for your input <3
post-14595687
Post #5,032 of 6,073
adrsz
sounds interesting. will read about the player.
so you think it doesn't make more sense to invest in a more expensive player for my needs?
post-14595725
Post #5,033 of 6,073
dsrk
If your main player is Spotify, none of these DAPs are close to mobile performance. Hiby R6 may be the fastest of the DAPs but that high impedance is always an issue.
The best way is to visit a nearby store and demo a few DAPs to see if you feel the sound quality is worth investing in DAPs.
post-14595800
Post #5,034 of 6,073
adrsz
as Mentioned before I will stick to my iPhone what doesn’t support aptx nor ldac.
What do you mean by „mobile performance“?
I guess I will go with the m9
post-14596074
Post #5,035 of 6,073
dsrk
Your phone speed and accuracy.
post-14596434
Post #5,036 of 6,073
bootster
USA
USA
This is a forum that is specific to the FIIO X7 MkII player that is Android based. You are in the wrong place. Thanks for your input.
post-14596749
Post #5,037 of 6,073
Halexx
Hello,
Since yesterday i'm having problem with Spotify. It says i'm in offline mode, but it won't let me access the control panel to put it bavk on online mode...
Only workaround i found is the uninstsll and install back thr software.
Any other suggestions?
post-14596884
Post #5,038 of 6,073
talan7
My phone is an apple as well but I use android phones as daps for streaming. Get a used LG V20/30 or Sony Xperia XZ. Any android 8 phone with a big screen would be excellent. I then turn on my tethering on my iPhone and use that for WiFi.
post-14599806
Post #5,039 of 6,073
Judge584
Hi,
I know X7mkII can be used as an external DAC for an android smartphone with usb. But does anyone knows if it is possible to do it over Bluetooth or Wifi?
post-14601049
Post #5,040 of 6,073
FiiO
Sponsor: FiiO
Guangzhou,China
Guangzhou,China
Age
13
Website
www.fiio.com
Hi,
Dear friend,
No, the X7MKII can not work as a DAC for mobile phone via Bluetooth or Wifi.
The USB DAC function of the X7MKII is designed for computer originally. So we could not promise whether it could be used as the DAC for Android smartphone you mentioned.
If you would prefer a player which can work as a receiver and transmitter, you may consider the M9 instead: https://www.fiio.com/m9
Best regards
https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com
