FiiO X7 Mk II 2GB RAM + 64GB ROM + ESS9028 PRO + Balanced + DSD + BT 4.1 aptX + Dual mSD + Dual Band WiFi + Opt Out
Discussion in 'Portable Source Gear' started by superuser1, Jul 6, 2017.
325 326 327 328 329 330 331 332 333 334
336 337 338 339 340 341 342 343 344 345
  1. snip3r77
    What about JP's fw??
    Or can you make US fw same as JP's ?
  2. Brooko Contributor
    Giullian likes this.
  3. lantian
    Well what else can you actually expect, Fiio doesn't have any real software engineers, Only people who dabble in some light coding work.
  4. Giullian
  5. superbike999
    For UK posters, EA Audio are currently selling the FiiO X7ii for £569 (instead of £599) at Amazon Uk - Fulfilled by Amazon
  6. Vitor Valeri
  7. dsrk
    majo123 likes this.
  8. majo123
    Amp3 players in the UK sells for £599 but this company always has good discount codes floating around I got 10% off mine through them.
  9. superbike999
    Yes that's quite true. I bought mine that way saving almost £60. The discount does vary though between 5 and 10%.
    If you browse https://www.advancedmp3players.co.uk/ and then move your mouse pointer towards the top of the screen, as if you are leaving the site, a pop up usually comes up with the discount.
    Today though, it is only offering 5%
  10. aqsw
    I have an x7 .1 with original firmware. It has an update firmware in the menu. Can I use this to update to newest firmware?
  11. goldenegg
  12. stenog
    Tidal has recently removed the crossfade option in the app. Do you still get stuttering?
    I use the X7II with Tidal and do not get any stuttering. But before they removed the crossfade options I set it to 1 second. Maybe the App still remember these settings?
  13. snip3r77
    Now 11.11 is over , is the new fw available?
  14. adrsz
    x7ii + tidal hifi /spotify premium + wh 1000 xm3
    makes sense ?
    stilleh likes this.
  15. haoyuan
    I am under the impression that Tidal only streams lossless on desktop clients, so for an android device the Hifi vs Premium in this case won't make a difference in SQ.
