FiiO X7 Mk II 2GB RAM + 64GB ROM + ESS9028 PRO + Balanced + DSD + BT 4.1 aptX + Dual mSD + Dual Band WiFi + Opt Out
Discussion in 'Portable Source Gear' started by superuser1, Jul 6, 2017.
305 306 307 308 309 310 311 312 313 314
316 317 318 319 320 321 322 323 324 325
  1. JaviAl
    No. I listen music continuesly with the SSD for about 5 or 6 hours.
  2. almo89
    I wonder if my X5 Gen 3 can power an SSD like that. Last time I tried to plug a portable hard drive and it couldn't power it up.
  3. JaviAl
    A hard disk drive (with mechanical parts, a motor to rotate the disk, head moving, etc.) requieres more power than a SSD that only have chips.
    Mike-WI likes this.
  4. almo89
    Good to know. Thanks!
  5. Jim Bobber
    I have the same problem pausing on the lock screen, first click never works, second one does!
    Vitor Valeri likes this.
  6. FiiO
    Dear friend,
    PM you just now. You could have a check.
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  7. russell finch
    Yes same for me.
    And if the screen is off and I press the play button on the side, the next thing I hear could be literally any track on the device.
  8. Paulo Abreu
    Yes, I think it happens only on the locked screen, and remember there is a customization for activating this play/pause button on locked screen, so it should work accordingly
    I think @FiiO should address this as a problem, its not "severe" but its annoying. Its true that after resuming from the 2nd pause it goes wherever it wants, beginning of track, other track...
  9. Vitaly2017
    Dear Fiio,
    Does x7m2 have a usb audio output to external dac?
    Also if use coax output can i still use the sound filters from x7 or its only a straight audio output?
  10. Vitaly2017
    Dear Fiio,
  11. Brooko Contributor
    Hi Vitaliy - it does work (USB out) but its a bit hit and miss, and depends on the device you are pairing with. I have success with the likes of their own Q5 and Q1ii.
    If you're using COAX and passing a digital signal to a DAC, the filters won't work - because you're passing a pure digital signal. the filters are for the X7ii DAC (which you are essentially by-passing).
    Vitaly2017 and superuser1 like this.
  12. Vitaly2017
    Thanks for the reply that is the info was looking for finaly.
    I am going to use an hdv 820 + hd800s.
    When I use my lg v30 via usb out with otg, i get pops and clicks and I also had this issue with other dacs. This is going be the same with fiio x7 mk2? Via usb out. I presume usb out will bypass the dac of fiio so no filters eather.
    Do you know if it can output audio in pcm format? That is what required for my hdv820 in coax mode.
    Thanks Brooko
  13. Paulo Abreu
    Yes. There is an option where you can inclusive define to convert or not a DSD source to PCM. AFAIR its "D2P" (DSD to PCM) and "DOP" (DSD Over PCM)
    I have D2P selected since my external DAC doesn't accept DSD on coaxial input.
    Regards
    Vitaly2017 likes this.
  14. x RELIC x Contributor
    DoP is still DSD, but in a PCM wrapper for DACs that require DoP to play DSD files. DoP is NOT DSD converted to PCM.
    Yes, all digital audio standards can output PCM.
  15. Paulo Abreu
    Thanks @x RELIC x for the info! I had it wrong.
    Regards
